The dark side
01-08-2013, 11:26 AM
The dark side
Right I'm considering going over to "the dark side" lol
20v install
I have no problem with the mechanics of the swap but what I'd
really like to know is about the ecu.
Currently the car has a 16v engine with a Freedom ecu running
through a stock blue top loom.
I would like to keep the Freedom ecu and that would mean keeping
the stock blue top wiring outputs from the ecu.
Freedom can run a 20v and I can tune it but will it be possible
for me to modify my loom to suit the 20v engine ?
Thanks for help with this.
01-08-2013, 11:32 AM
The dark side
I dont see how it will work? AFM to MAP based?
01-08-2013, 11:44 AM
The dark side
MAP based
Apart from vvt are there any other differences with the engines ?
The ecu can run Alpha n for the itb's
01-08-2013, 05:48 PM
The dark side
What ecu are you running? Omex/ Emerald/ Motec/etc?
Should be not problem if its a proper ECU! If you want it cheap a little bit of soldering a lot of reading and crossreferencing.
There are a few thing different on a 20V BT, idle up valve, rpm signal etc. Not saying it can´t be done but lot of work and still a 20year old loom!
And you gonna need a remap anyway, obviously...
BUT I´d recomend a new custom loom, you can buy the ecu plug with wires/ pins seperate for your ecu (if its no piggy back shit) and use the OEM senders/ connectors and solder it to the new loom, this is also a good way to ditch the dizzy (and avoid buying a relocation kit) for a coil pack.
I´ve just done this at work, 20V blacktop on omex using a new loom with the OEM plugs. Very easy to build and a lot neather as a chopped OEM loom.
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
01-08-2013, 05:54 PM
The dark side
fax0815 Wrote:What ecu are you running?
Reading carefully before giving an answer can help a lot Tongue
totta Crolla Wrote:Currently the car has a 16v engine with a Freedom ecu running
For me I don't see any problem using your current ECU for a 20v.
I would have to watch again my 86club to be 100% sure, but I'm pretty confident on the fact that Tsuchiya's Trueno run with a Freedom ECU.
01-08-2013, 06:05 PM
The dark side
How exactly does your post help?
I start by naming freedom ECU´s, fell free to add more Wink:
Motec, Vipec, Emerald, Omex, Haltech, Trijekt, Bosch, Megasquirt...
Edit: What a stupid company whould give themself such silly name? It´s like beeing a BMW main dealer and having "new cars" as a company name... or beeing a company that does wooden shelfs naming themselfs "wood"...
Sorry no expirience with a so called "freedom ecu", sorry...
01-08-2013, 06:11 PM
The dark side
Freedom is an ecu's brand !
[Image: AEU86 AE86 - The dark side]
http://www.e-freedom.co.jp Wave
Omex motec etc.. are "standalone" ECUs, not "Freedom" ECUs
01-09-2013, 12:09 PM
The dark side
Hey no problem guys, there has been some confusion over the
naming of the ecu before and I forgot that "freedom" it seems can
be a generic name for a programmable ecu.
I'm sorry I wasn't a bit clearer about that.
Some valid points about the idle valve and my ecu can control the 20v
idle valve if I can find the output pin from the ecu.
There is also a chance that it can control the vvc too.
01-09-2013, 03:05 PM
The dark side
http://t2.gstatic.com/images?q=tbn:ANd9G...n41t-klbJ1
The original picture was available on club4ag, but the site seems to be down Sad
01-09-2013, 05:22 PM
The dark side
aaah....
Perfecto Thumbs up!
Thanks
  Fibreglass side mirror options? 4000GT 11 20,787 04-16-2011 03:30 AM
Last Post: 4000GT
  4age intake side (port) dimensions Uzelac 15 35,492 03-03-2011 12:43 AM
Last Post: Uzelac
  OEM side mirrors AE86 (Levin coupe) Okami 2 5,332 05-24-2010 08:37 AM
Last Post: Okami
  What side mirrors fits on the Hachi? Allexz 4 6,579 08-06-2009 09:35 PM
  How to dismount side skirts? pedro-siR 3 4,182 03-14-2008 05:24 PM
Last Post: pedro-siR
User(s) browsing this thread: 12 Guest(s)
