The parts i´ve gathered for winter
11-05-2004, 03:07 PM
Here´s an overview of the parts i´ve come across and had to buy for the winter restoration. I do not currently have any pictures of my completley disassemlied red-top, and the ITB´s i´ve bought. But i still think i´m pretty much good to go.
I also made a deal on a rustfree rear hatch in silver wich will be mounted during winter.
the parts:
http://www.123hjemmeside.dk/ClaraRuggeri/108356
The car:
11-05-2004, 03:22 PM
Looks nice Peter, and you already had a nice car to start from...
Why don't you add some RCA's and be done with it? Should make a real difference in handling.
11-05-2004, 03:24 PM
Hey nohachi....I allready have the T3 NCRCA´s but I didn´t take a picture before installment. Hurray!
11-05-2004, 03:38 PM
You have a nice collection of parts...I wish I had some more space to store things around the house.
Anyway, best of luck on the ITB installation, I'd like to hear your redtop roaring with those ITB's once it's done.
11-05-2004, 04:44 PM
peter møller Wrote:Here´s an overview of the parts i´ve come across and had to buy for the winter restoration. I do not currently have any pictures of my completley disassemlied red-top, and the ITB´s i´ve bought. But i still think i´m pretty much good to go.
the parts:
The car:
Nice parts! I have the same T3 parts as well!
How are you going to run your ITB? I have a set as well, which intake manifold you using? Smile Smile
11-11-2004, 03:06 AM
I just ordered the T3 ITB adapter today from Gabriel at Technotoytuning.com He said it was just a matter of bolt and go! It is allready prepared for mounting of the original throttle cable, and all you need is to cut open the wiring harness and extend the cables for the throttle position sensor. All this is only possible with a MAP type engine, if you are running a MAF engine, you need to convert into MAP.
You do need a stand-alone engine management, and bigger injectors, either the 20V or the 4AGZE injectors. But the adapter plate should be pretty easy installed.
http://www.technotoytuning.com/media/t3/...apter3.jpg
11-11-2004, 06:33 PM
peter møller Wrote:I just ordered the T3 ITB adapter today from Gabriel at Technotoytuning.com He said it was just a matter of bolt and go! It is allready prepared for mounting of the original throttle cable, and all you need is to cut open the wiring harness and extend the cables for the throttle position sensor. All this is only possible with a MAP type engine, if you are running a MAF engine, you need to convert into MAP.
Cool, when are you starting to build yours? Also, what ECU will you be using?
11-11-2004, 09:12 PM
Hey pete how are your charis you seem to have removed them i still me a good backplate
same colour interieur
11-12-2004, 12:11 AM
robokill Wrote:Hey pete how are your charis you seem to have removed them i still me a good backplate
I´m really sorry Robokill....I just don´t understand what you are saying Huh Smile
11-12-2004, 01:43 AM
Sheesh Robo...stop talking in codelanguage, no newspeak allowed eh.
I think he meant to ask you if you have some spare stock chairparts left since you have a sportsseat installed.
  New Winter and new drifts Widar 15 12,709 12-05-2005 11:30 PM
Last Post: lasse
