Toda 288 - Cam timing
06-24-2009, 10:28 AM
Does anyone have, or know where I can find the suggested cam timing specs for a set of Toda 288 7.9mm lift cams?
I have searched the net but can’t find the manufacturers suggested cam timing. Cheers James ![]() http://www.eight-six.co.uk - read the blog! UK AE86 Forum - http://www.phpbber.com/phpbb/index.php?m...ghtsixcouk |
06-24-2009, 11:25 AM
I thinck Apradal can help you on this point
![]() SR Team BURN THE RUBER NOT YOUR SOUL! |
06-24-2009, 12:12 PM
Awesome – Apardals thread gave me the answer I needed.
06-24-2009, 12:45 PM
Any link to the thread, have cams on the way
06-24-2009, 01:43 PM
This is what I got from one of the posts in the thread.
Max Lift @ IN 100 ATDC/ EX 100 BTDC, or 100/98. Determine true TDC of piston #1 in phase 2 of cycle. Mark on degree wheel. Turn crank & degree wheel 100 ATDC (clockwise) Twist inlet cam in the adj gear until Max Lift occurs. Tighten screws. Turn crank & degree wheel 100 BTDC (anti-clockwise) Twist ex cam in the adj gear until Max Lift occurs. Tighten screws. Cam timing should be set. ![]() http://www.eight-six.co.uk - read the blog! UK AE86 Forum - http://www.phpbber.com/phpbb/index.php?m...ghtsixcouk |
06-24-2009, 03:23 PM
Cheers,
Now the shim collection starts An 86 is for Life, not just for Christmas |
06-25-2009, 05:12 PM
which your prj mate?
**COROLLA EE80 - 4AGE 124HP** ![]() |
Kelford vs Toda | Gates Racing vs Toda for 16v | mister86 | 2 | 3,974 |
06-10-2020 04:43 PM Last Post: Lykowsky |
20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 14,161 |
Cam Cap Bolt Snapped!! | Alex170984 | 1 | 3,901 |
06-08-2018 01:17 PM Last Post: Ivan141 |
TODA head assemble | Jimmi The Kid | 5 | 6,848 |
03-05-2018 08:37 PM Last Post: Jimmi The Kid |
HKS 260 8.0 Cam Card | d3nso | 5 | 7,289 |
02-14-2018 08:29 PM Last Post: oldeskewltoy |
