Toda 288 - Cam timing
06-24-2009, 10:28 AM
Does anyone have, or know where I can find the suggested cam timing specs for a set of Toda 288 7.9mm lift cams?
I have searched the net but can’t find the manufacturers suggested cam timing.
Cheers
James
[Image: AEU86 AE86 - Toda 288 - Cam timing]
http://www.eight-six.co.uk - read the blog!
UK AE86 Forum - http://www.phpbber.com/phpbb/index.php?m...ghtsixcouk
06-24-2009, 11:25 AM
I thinck Apradal can help you on this point Wink PM him
SR Team
BURN THE RUBER NOT YOUR SOUL!
06-24-2009, 12:12 PM
Awesome – Apardals thread gave me the answer I needed.
06-24-2009, 12:45 PM
Any link to the thread, have cams on the way
06-24-2009, 01:43 PM
This is what I got from one of the posts in the thread.
Max Lift @
IN 100 ATDC/ EX 100 BTDC, or 100/98.
Determine true TDC of piston #1 in phase 2 of cycle.
Mark on degree wheel.
Turn crank & degree wheel 100 ATDC (clockwise)
Twist inlet cam in the adj gear until Max Lift occurs.
Tighten screws.
Turn crank & degree wheel 100 BTDC (anti-clockwise)
Twist ex cam in the adj gear until Max Lift occurs.
Tighten screws.
Cam timing should be set.
06-24-2009, 03:23 PM
Cheers,
Now the shim collection starts
06-25-2009, 05:12 PM
which your prj mate?
**COROLLA EE80 - 4AGE 124HP**
  Kelford vs Toda | Gates Racing vs Toda for 16v mister86 2 3,857 06-10-2020 04:43 PM
Last Post: Lykowsky
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 13,871 07-18-2019 03:52 PM
  Cam Cap Bolt Snapped!! Alex170984 1 3,838 06-08-2018 01:17 PM
  TODA head assemble Jimmi The Kid 5 6,708 03-05-2018 08:37 PM
Last Post: Jimmi The Kid
  HKS 260 8.0 Cam Card d3nso 5 7,123 02-14-2018 08:29 PM
