Tomei Strengthened Timing Belt Now Available!!!
06-03-2011, 12:50 AM
We are Authorize Dealer for Tomie.
The Timing Belt is a common part of the engine, but not all OEM and aftermarket timing belts are designed for highly tuned engines. The increased stress load of aggressive camshafts, uprated valve springs, and extreme heat can cause premature wear and failure of the timing belt. The Tomei Powered Strengthened Timing Belt is designed and manufactured with a kevlar fiber (Aramid) belt surface, H-NB rubber, and glass cable core for increased tensile strength and durability. This results in consistent and precise valve timing, ensure engine is operating at optimum, and keep everything in check under extreme conditions. Detail of the Products: Section: -Rubber -Cable Core -Belt Surface STD: -H-NBR -Glass -Nylon Tomie: -High Saturation H-NBR -High Strength Glass -Kevlar + Nylon Life Comparison: -Cutting Prevention [3-4x more] -Heat Proof [2-4x more] -Crack Prevention [3-4x more] -Wear Proof [2-3x more] *Compared with the STD belt Happy with what you see? Please dont hesitate to PM or Call to put your order in because the products will go fast!!! Again Thank You for your interest. Feel free to call or pm for any question comments or concerns! Your opinion matters to us! Thank You And Have A Great Day!!! Matt Spirits Auto 1938 Tyler Ave, Unit E168 El Monte CA 91733 (626)329-0303 [email protected] http://www.spirits-autoworks.com AIM or Meebo: spiritsales01 Contact information: Leon, Matthew Spirits autoworks 1938 Tyler Ave, E168 S. El Monte, CA 91733 USA Phone number: +16263290303 Email: [email protected], [email protected], [email protected] AIM: spiritsracing, spiritsales01, spiritssales02 |
06-13-2011, 07:58 PM
Bump it UP !!
86 Garage Magazine: Back Issues now available on Kindle | dr.occa | 0 | 4,696 |
01-19-2015 06:30 PM Last Post: dr.occa |
Group A ---- Tomei Authorized Dealer LSD, Pon Cams, Pro Cams | Group A | 15 | 23,181 |
09-24-2012 11:42 PM Last Post: Group A |
RPS13, R34, GD8 and LOTS OF RIMS shirts now out! | import_bible | 1 | 4,235 |
01-04-2012 10:26 PM Last Post: import_bible |
Project Mu Rotors Now Available!!!! | Spirits Racing | 1 | 4,541 |
06-16-2011 01:13 AM Last Post: Spirits Racing |
KoyoRadiator are now available for Pre-Order!!! | Spirits Racing | 2 | 4,786 |
06-13-2011 07:58 PM Last Post: Spirits Racing |
