Torque specs for flywheel?
07-07-2006, 04:35 PM
Heh guys are they any torque specs for flywheels and pressure plate? thanks. I need to bolt on my recently aquired ones to my engine
[Image: AEU86 AE86 - Torque specs for flywheel?]
07-10-2006, 06:38 PM
Confused has this imformation been posted before i tried searching but if found nothing really but people mentioning there flywheels. doesnt anyone know please help thanks
07-11-2006, 07:56 AM (This post was last modified: 07-15-2019 09:30 PM by banpei.)
Download the factory manuals...
You'll find the AE86 manual here:
http://files.aeu86.org/manuals/AE86Manual.pdf
And for flywheel torque specs go here:
http://files.aeu86.org/manuals/4A-GEManual.pdf
OEM torque specs should suffice for most applications I suppose.. the OEM flywheel is the heaviest and puts the biggest load on those bolts so any lightweight flywheel will probably work fine at the same bolt torque.
07-11-2006, 02:15 PM
Thanks man
  AE86 Battery specs hachirokuGTV 9 16,337 03-13-2020 04:16 PM
Last Post: Power_uP
  light weight Flywheel filh 9 7,254 02-05-2018 05:20 PM
Last Post: filh
  Torque settings kazi 4 6,846 03-28-2017 12:15 AM
Last Post: kazi
  crank 6 bolt flywheel DJexor 5 7,978 12-05-2016 08:21 AM
Last Post: d3nso
  torque setting head cylinder bolts izanagi 1 4,878 05-29-2015 01:23 AM
