Torque specs for flywheel?
07-07-2006, 04:35 PM
Heh guys are they any torque specs for flywheels and pressure plate? thanks. I need to bolt on my recently aquired ones to my engine
"life begins at 8000rpms" - Going Racing |
07-10-2006, 06:38 PM
has this imformation been posted before i tried searching but if found nothing really but people mentioning there flywheels. doesnt anyone know please help thanks
07-11-2006, 07:56 AM
(This post was last modified: 07-15-2019 09:30 PM by banpei.)
Download the factory manuals...
You'll find the AE86 manual here: http://files.aeu86.org/manuals/AE86Manual.pdf And for flywheel torque specs go here: http://files.aeu86.org/manuals/4A-GEManual.pdf OEM torque specs should suffice for most applications I suppose.. the OEM flywheel is the heaviest and puts the biggest load on those bolts so any lightweight flywheel will probably work fine at the same bolt torque. FABRICA MI DIEM, PVNC! |
07-11-2006, 02:15 PM
Thanks man
AE86 Battery specs | hachirokuGTV | 9 | 16,685 |
03-13-2020 04:16 PM Last Post: Power_uP |
light weight Flywheel | filh | 9 | 7,347 |
02-05-2018 05:20 PM Last Post: filh |
Torque settings | kazi | 4 | 7,050 |
03-28-2017 12:15 AM Last Post: kazi |
crank 6 bolt flywheel | DJexor | 5 | 8,137 |
12-05-2016 08:21 AM Last Post: d3nso |
torque setting head cylinder bolts | izanagi | 1 | 4,950 |
05-29-2015 01:23 AM Last Post: oldeskewltoy |
