Toyota Special Service Tools (SST)
12-29-2008, 09:01 PM
Last summer my father was in Mannheim, Germany.
On a European biggest Veteran Market "VETERAMA" and he bought some souveniers to me...a big box where was a Toyota Special Service Tools and some other tools.
Now I need a help to find out where these are made for...
Pics with P/N
SOLVED:
09201-60010 valve guide replacer (WHAT ENGINE?) NOT 4A-GE
09303-35010 input shaft front bearing puller (T- and A-engine)
09304-12012 input shaft front bearing replacer (T-engine)
09307-12010 extension housing bushing replacer (T50)
09330-00020 companion flange holding tool (UNIVERSAL)
09504-00010 diff. side bearing adjusting nut wrench (6.7")
09506-30010 diff. drive pinion bearing cone replacer (6.7")
09608-30030 diff drive pinion front bearing cup (6.7")
09806-30010 window shield moulding remower
09737-22011 Brake Booster Push Rod Gauge
09527-20011 Rear Axle Shaft Bearing Remover
09304-30012 Input Shaft Front Bearing Replacer (A-engine)
09718-20010 Brake Shoe Return Spring Replacer
09732-14010 rear axle stand (when springs are remowed) (TA22, TA12)
2-line timingchain cutting/extension tool
09301-12020 clutch guide tool (kp36,ke70,tt132/133,rt132,rt134)
09506-10010 differential drive pinion rear bearing remover (te71/72, ta40/47)
09810-25010 switch lock nut wrench (ma46,mx32/36)
09812-14010 door hinge set bolt wrench set (km20,rh11/20/30,rh22/25/32/42,lh11/20/30)
"Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!"
""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff"
-Henri Toivonen 2.5.1986-
http://www.youtube.com/watch?v=OwgB4Xs4LVQ
10-25-2009, 05:13 AM
Several of your tools date back to the 1960's. Of particular interest to me are the ones that fit the U and 2U engines. Let me know if you wish to sell any? PM me and I will send you the list.
Thanks,
Rich
  Need special parts gh0st 4 3,189 09-11-2021 02:23 PM
Last Post: gh0st
  SPECIAL AE86 WHEELS GUIDE !!! eg6maxx 51 324,432 09-02-2012 12:31 PM
Last Post: Skyracer
  SST (Special service tools) questions. Ryo 4 7,989 04-06-2011 07:51 PM
Last Post: Ryo
  AE86 Service Manual Help! d-junkie 2 4,078 02-04-2008 10:01 AM
Last Post: Mux213
  Is my 86 special?!? Jan Pedersen 25 22,088 03-30-2007 01:48 AM
Last Post: parrot
