Toyota Special Service Tools (SST)
12-29-2008, 09:01 PM
Last summer my father was in Mannheim, Germany.
On a European biggest Veteran Market "VETERAMA" and he bought some souveniers to me...a big box where was a Toyota Special Service Tools and some other tools. Now I need a help to find out where these are made for... Pics with P/N SOLVED: 09201-60010 valve guide replacer (WHAT ENGINE?) NOT 4A-GE 09303-35010 input shaft front bearing puller (T- and A-engine) 09304-12012 input shaft front bearing replacer (T-engine) 09307-12010 extension housing bushing replacer (T50) 09330-00020 companion flange holding tool (UNIVERSAL) 09504-00010 diff. side bearing adjusting nut wrench (6.7") 09506-30010 diff. drive pinion bearing cone replacer (6.7") 09608-30030 diff drive pinion front bearing cup (6.7") 09806-30010 window shield moulding remower 09737-22011 Brake Booster Push Rod Gauge 09527-20011 Rear Axle Shaft Bearing Remover 09304-30012 Input Shaft Front Bearing Replacer (A-engine) 09718-20010 Brake Shoe Return Spring Replacer 09732-14010 rear axle stand (when springs are remowed) (TA22, TA12) 2-line timingchain cutting/extension tool 09301-12020 clutch guide tool (kp36,ke70,tt132/133,rt132,rt134) 09506-10010 differential drive pinion rear bearing remover (te71/72, ta40/47) 09810-25010 switch lock nut wrench (ma46,mx32/36) 09812-14010 door hinge set bolt wrench set (km20,rh11/20/30,rh22/25/32/42,lh11/20/30) "Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!" ""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff" -Henri Toivonen 2.5.1986- http://www.youtube.com/watch?v=OwgB4Xs4LVQ |
10-25-2009, 05:13 AM
Several of your tools date back to the 1960's. Of particular interest to me are the ones that fit the U and 2U engines. Let me know if you wish to sell any? PM me and I will send you the list.
Thanks, Rich |
Need special parts | gh0st | 4 | 2,921 |
09-11-2021 02:23 PM Last Post: gh0st |
SPECIAL AE86 WHEELS GUIDE !!! | eg6maxx | 51 | 320,089 |
09-02-2012 12:31 PM Last Post: Skyracer |
SST (Special service tools) questions. | Ryo | 4 | 7,699 |
04-06-2011 07:51 PM Last Post: Ryo |
AE86 Service Manual Help! | d-junkie | 2 | 3,923 |
02-04-2008 10:01 AM Last Post: Mux213 |
Is my 86 special?!? | Jan Pedersen | 25 | 21,059 |
03-30-2007 01:48 AM Last Post: parrot |
