Toyota Sprinter AE86 GT-Apex Trueno
12-07-2014, 03:04 PM
Post: #151
(12-05-2014 05:10 PM)pack Wrote: He makes the side outlet? I dont know what you mean. I just ordered everything for a 20V swap. I just have to buy the NZ1 coils. I forgot to put the "Water plug" in the picture, which goes somewhere. I bought the Haltech PS1000. Cam gears are on the way from Tomei, and I found the Tomei Poncams in Okinawa. I think I will understand more which thing goes where once I start to put time on the engine. Im giving the gear box to a company next week for service and the engine head goes to porting after new year. Regards Håkan AE86 SWEDEN https://www.facebook.com/ae86sweden |
12-07-2014, 04:44 PM
Post: #152
(12-07-2014 03:04 PM)Skyracer Wrote:let me help you out here: the answer is yes(12-05-2014 05:10 PM)pack Wrote: He makes the side outlet? http://www.s-86.com/20v_rwd_cooling_kit.php AE86 ex-daily |
12-15-2014, 11:51 AM
Post: #153
Im not able to find any Tomei cams anywhere in the world, so I just have to order them from Tomei with delivery in April 2015 :/
12-15-2014, 12:15 PM
Post: #154
(12-15-2014 11:51 AM)Skyracer Wrote: Im not able to find any Tomei cams anywhere in the world, so I just have to order them from Tomei with delivery in April 2015 :/what spec cams are you looking for and are you dead set on tomei? AE86 ex-daily |
12-15-2014, 01:17 PM
Post: #155
Hmm i see..... It's a different concept....
I'll make one using stainless steel Can't buy from RS CHITA.... :\ |
12-15-2014, 03:01 PM
Post: #156
(12-15-2014 01:17 PM)pack Wrote: Hmm i see..... It's a different concept....Have you tried e-mailing perfectrun.jp? AE86 ex-daily |
12-15-2014, 03:51 PM
Post: #157
Yes, I have emailed alot of resellers, from Hawaii to Japan, incl. Perfectrun but they all order from Tomei and Tomei are out of material at the moment.
And I want the special ones, so called Poncams for 20V Black Top which works with the VVT. But I can do everything else on the engine, like the head porting. And leave the Red Top in for now, just in case something happens that makes the time go into the Time Attack 2015 season, and I have to run with the Red Top. Regards Håkan AE86 SWEDEN https://www.facebook.com/ae86sweden |
12-15-2014, 04:28 PM
Post: #158
(12-15-2014 03:51 PM)Skyracer Wrote: Yes, I have emailed alot of resellers, from Hawaii to Japan, incl. Perfectrun but they all order from Tomei and Tomei are out of material at the moment.Have you ever considered catcams, they do have almost same spec cams http://www.catcams.com/engines/camshaft-setup.aspx even with more lift if you want. If I remember right they should be in the same price range. AE86 ex-daily |
12-15-2014, 05:03 PM
Post: #159
I havent really considered anything else than Tomei, since I have their cam gears. I dont know why I just wanted them since the swedish reseller is helping me with Tomei parts, mounting and mapping
12-15-2014, 05:15 PM
Post: #160
Sorry for the offtopic,
I contacted perfectrun, but the issue is that i need only a piece from the RS CHITA kit... i don't want to order the full kit from them. Perfectrun couldn't help me :\ I also want to cams! Skyracer what specs are you searching?! |
JDM GT-Apex Trueno in the Alps # | decryphe | 107 | 82,068 |
10-16-2024 02:46 PM Last Post: decryphe |
Hybrid to fossil burner - 84 Sprinter Trueno | dasilva | 31 | 24,716 |
12-23-2019 05:29 PM Last Post: Power_uP |
White Kouki Levin Coupe GT-APEX ++As original as possible++ | asw | 24 | 42,481 |
12-28-2010 10:33 AM Last Post: worholm |
JDMitch's 1983 Sprinter Trueno AE86 Panda | JDMitch | 24 | 34,032 |
09-01-2010 11:37 AM Last Post: nunoturbo |
Parrot's Sprinter & Levin shed | parrot | 23 | 39,238 |
10-12-2009 01:43 PM Last Post: parrot |
User(s) browsing this thread: 12 Guest(s)
