Track and road brake kits
09-11-2012, 04:36 PM
We're currently developing a number of new brake kits for fast road and track use, should have a kit using 260 x 23mm discs for cars running 13" wheels and a kit using 280 x 25mm discs for cars running 15" wheels
Two piece steel mounting bracket, needs to be drilled and tapped yet but you get the idea! Assembled with 275mm drilled disc |
09-11-2012, 05:21 PM
sounds nice, if I can have it for 1€ I'm in - else I'll keep my OEM setup with aftermarket pads
honestly it's all down to the price... there are already quite a few options out there, so unless you develop something really new I don't see the point unless you are cheaper than the alternatives. AE86 ex-daily |
09-12-2012, 09:49 AM
these will be on sale for €600 per kit including calipers, discs, pads, lines and all fittings so i think we are fairly competitive price wise
09-12-2012, 05:43 PM
275mm kit fitted to my 14" ssr mesh without any problems
09-12-2012, 07:06 PM
Which willwood calipers are you using and what's the overall weight (compared to stock if you have the numbers)?
AE86 ex-daily |
09-12-2012, 07:51 PM
Bean, you have the part number on the caliper -> 120-6805 = Dynalite
http://www.wilwood.com/Calipers/CaliperP...o=120-6805 |
09-12-2012, 09:21 PM
Looks nice and I like how it fits 14" wheels! But the pads aren't that much bigger than stock ones.
I just went for RX7 / Mini brakes which adds up to €550 so you are a bit late in my case Sarcasme is just one of the things I offer Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch |
09-12-2012, 10:23 PM
The thing I don't like about this particular setup is the fact the calipers in question don't have dust boots which is fine in a race application but a no go for a road car in my opinion.
AE86 ex-daily |
09-13-2012, 09:41 AM
true there are no dust boots on the pistons but there is a seal fitted internally and the pistons are made of stainless steel
09-13-2012, 10:22 AM
What type of discs will it use? Available off the shelf or do replacements need to be custom ordered? Are they the std redrilled Corrado stuff?
AJPS.com.au - - STEERING LOCK SPACERS and REAR brake upgrade | AJPS | 5 | 13,450 |
04-30-2014 05:10 AM Last Post: AJPS |
Group A --- Body Kits Jblood, Vertex, RunFree, Goodline | Group A | 20 | 38,950 |
03-20-2013 10:01 PM Last Post: alimonos |
Wilwood Brake Kits €600 each | ep71 | 14 | 33,352 |
01-18-2013 01:04 AM Last Post: TheGerman |
AE86 adjustable Track control arms/pair | ep71 | 1 | 4,354 |
07-27-2012 01:11 PM Last Post: ep71 |
AE86 Rose jointed track rod end kit | ep71 | 1 | 4,109 |
05-24-2012 05:46 PM Last Post: ep71 |
