Trouble with idle speed
12-22-2005, 12:09 AM
Ivan141 Wrote:I dont know any thermostat that will raise the temps, but you can use pretty much any corolla thermostat for 4A engines, they're all the same.
How far do your temperatures drop? On my car the coolant got cold while driving on the highway, and my heater also had zero effect. That was due to a broken thermostat. But you should notice the meter going down to around 1/4 of the scale and lower if that's the case.
I think the thermo must be broken the. When driving it is around 1/4. Should bé around 1/3 or even 1/2. Lastnight just left the car sitting outside running for a while. It slowly droped the idle speed to just under 1000rpm, but very slowly, and got warmer too i think. I really think it must be the thermostat, cant imagen of any other thing that might cause this in that exact order.
Jón Mar
"T3 is good. I'd go with them. And they're red. Red goes faster..."
'87 AE86 3dr - Black
'87 AE86 3dr - Red
'88 AE92 5dr GTi - Black
'95 ST205 - Red - sold
12-22-2005, 11:23 AM
Yep...the symptoms are clear....It's an easy fix. Dont forget to buy a new gasket for the housing while your at it.
  No idle below 2000 rpm rich running Steller Engineering 3 1,691 11-30-2022 02:45 PM
Last Post: RolanTHUNDER
  Engine starts/revs but no idle GenkiMotors 17 8,081 11-20-2021 04:12 AM
Last Post: GenkiMotors
  exhaust odor/idle MOT issue Ryo 7 7,779 07-15-2019 09:17 AM
Last Post: jondee86
  20v silvertop idle issue AlexFourTwenty 3 5,396 12-24-2017 03:27 AM
Last Post: AlexFourTwenty
  Silver top low idle AlexFourTwenty 7 10,624 10-16-2017 10:22 PM
User(s) browsing this thread:
