URGENT QUESTION
01-23-2008, 09:21 PM
URGENT QUESTION
this part is thread M14
fits on the original shock
but not on the koni
the koni is M12
[Image: AEU86 AE86 - URGENT QUESTION]
so i need this in M12
or do i just cut the nut of and use the spacer and then the nut from the koni
and why is there another spacer in the camber plate kit?
als ik die extra spacer onder de camberplate zet krijg ik de moer er boven niet meer op
en als ik em bovenaan zet ook dus...
No Smorking AE86
01-23-2008, 10:07 PM
URGENT QUESTION
im with AE86 KONI Yellow, and T3 plates - i fitted it without any problems or additional parts
84' AE86 Levin
96' 500HP WRX, powered by landikar
01-23-2008, 11:23 PM
URGENT QUESTION
i did not use any spacer at all.
Spring, on top of that the spring cup, on top of that the camber plate and then i just used the stock koni nut (without the sleeve going in the pillowball). Works perfect.
01-24-2008, 11:34 AM
URGENT QUESTION
I tried both Tein and AEU86 plates last night and indeed the nut doesn't fit both of them... Both of them have 14 nuts instead of 12 which are needed to make the Konis fit.
Did some searching and came across these topics:
http://www.aeu86.org/viewtopic/which-cam...ers/t/5199
http://www.aeu86.org/viewtopic/fitting-c...uts/t/5828
Solution of Doc will work, but the biggest problem is that the top part of the konis is smaller than the camberplates pillowball and it can have some free-play.
Probably best thing to do is cut off the top part of supplied nut with the camberplate and then use the Koni on top of that... Or has Jamiemirror a better solution? Dumb question
01-24-2008, 11:43 AM
URGENT QUESTION
banpei Wrote:Solution of Doc will work, but the biggest problem is that the top part of the konis is smaller than the camberplates pillowball and it can have some free-play.
Yeah we talked about it last night, and that was what we are going to try today, thanks for all the info and fast replies Thumbs up!
No Smorking AE86
01-24-2008, 08:43 PM
URGENT QUESTION
banpei Wrote:I tried both Tein and AEU86 plates last night and indeed the nut doesn't fit both of them... Both of them have 14 nuts instead of 12 which are needed to make the Konis fit.
my AE86 konis together with Cusco Camberplates and stock koni nut had NO play at all. I was afraid of that too, but it didn't feel anything. the tapered section on the nut is enough to keep the shock centered. For shure the koni nut will be better, but as an in-between solution it works perfect.
01-24-2008, 09:37 PM
URGENT QUESTION
Thanks banpei for checked it out. BTW I emailed tein in UK and they told me you can buy the bolts from their supplier. I already called one of tein suppliers here in Holland, so he tell me to bring the camberplates and my car to his place because he got alots of those stuff around. I will go to there one of this days Smile
01-25-2008, 09:26 AM
URGENT QUESTION
Cool Smile
Can you ask them the partnumber for reference?
01-25-2008, 08:06 PM
URGENT QUESTION
konis are not m12 they are something specific, they have very fine thread
(engelse maat??)
i tried the solution sugested by cutting of the nut and using the koni one but it wont fit
i fitted this: spring, spring cub, camberplate, and then there is not enough thread over to fit the koni nut
hope you come with a solution
just put the koni's on without the camberplates, the are a great improvement for drifting, now just need to be able to change the camber
No Smorking AE86
  Urgent replies needed DIFF OIL + refresh Okami 6 6,497 06-17-2012 09:56 PM
Last Post: Okami
  Need urgent help strut mounts. ditn 5 7,656 01-21-2012 03:37 PM
Last Post: ditn
  URGENT: Need electric help, injectors not fireing ZaX 13 16,044 07-05-2011 01:10 PM
Last Post: Nomuken
  Urgent Levin hood question... measurements and weight Okami 8 14,150 03-15-2011 11:36 PM
Last Post: Gtsi-R
  Urgent. AE86 Door hinge bolt numbers. Need help hachirokuGTV 2 5,226 09-19-2010 08:16 PM
Last Post: hachirokuGTV
