US GTS Trueno stereo wiring
01-25-2005, 12:24 AM
Could anybody in here explain me the use of the following wires of the original Toyota stereo wiring (BIG & SMALL harness)?
01-25-2005, 12:42 AM
Why dont you just get a multimeter and check it out..?
01-25-2005, 02:20 AM
Well i'm not very fond of electric/electronics... Crying
I managed to connect some of them and power it up but the speakers didn't work Angry
That's why i'm asking if somebody know something...
01-25-2005, 11:46 AM
Well, only plex and osmosis could know that about US models, but often these connectors are cut by previous owners. If you have a multimeter you could check for power, contact and lighting feeds by measuring voltages on the connectors. Looking at the connector layouts I would hazard a guess that the small connector is for power supply and dashlighting etc..(1 ground, 1 permanent 12v, 1 contact 12v, 1 lighting).
The bigger connector has exactly 8 connections so that corresponds nicely to 4 speakers.
You cant damage the speakers by experimenting, so just connect the radio (after checking what each of the power feed connectors exactly is, sometimes the radio wont play without contact wired correctly).
Then use two speaker outputs on the radio and just keep searching for a pair on the connector where you get sound.
Not so difficult I suppose...
But I do urge you to check for voltage on all connectors with the contact on before you do anything else...
01-25-2005, 12:05 PM
Thanks Ivan! I 'll give it a try and ... god help me not to toast the radio :wink:
01-26-2005, 02:01 AM
Finally i managed to establish right connections! Smile
Great help i had from site : http://www.installdr.com Respect!
Instructions for everyone to install a car stereo in almost every car!
Great site guys... add it to your favorites! Thumbs up!
  Tail light wiring... Mylesmck 4 907 02-02-2024 12:36 PM
Last Post: Mylesmck
  Lambda sensor wiring sam3007 10 4,202 05-23-2022 10:00 PM
Last Post: The Doctor
  4A-GE wiring engine to chassis connectors Lykowsky 4 6,840 06-20-2019 11:38 AM
Last Post: Lykowsky
  Some wiring help needed DJexor 5 5,383 05-18-2019 01:50 PM
Last Post: DJexor
  AE86 Headlight + wiper wiring (levin) bozu 11 15,695 09-19-2017 02:06 PM
