USA New Member
05-22-2006, 11:19 AM
USA New Member
banpei Wrote:So, actually people are tuning the 4AC actively Once in Club4AG I read about one tuned 4AC SR5 hachi - with up to 170hp@crank. Maybe owner use some 4AGE internals, 11+CR, cam + carbies - I won't really know, he wrote aomethink about hi-CR and Paradise Racing power kit for 4AC. He wrote that he turned 18.5 sec car to 15.8 sec one :-) |
05-22-2006, 08:26 PM
USA New Member
Impressive
05-23-2006, 09:50 AM
USA New Member
But banpei, if your goal is 170hp from 1.6 displacement - you can achieve it with SOHC 8V also - the DOHC 16V is not requirement. You can obtain very hight VE values even for such SOHC head with extensive P&P job, big valves, good cam etc. Stock 4AC is weak over 4500 RPM due to poor head/intake/exhaust header design but all these can be improved. I don't know exactly are 4AC internals good for continuos 6000+RPM or not (mine was "tested" over 7000RPM and survived, 100% stock engine).
4AC suffer also from low CR (~9). PS: This is not easy modification and definitely is more expensive than 4AGE engine swap (at least in Bulgaria). |
05-25-2006, 12:46 PM
USA New Member
jamiemirror Wrote:But banpei, if your goal is 170hp from 1.6 displacement - you can achieve it with SOHC 8V also - the DOHC 16V is not requirement. You can obtain very hight VE values even for such SOHC head with extensive P&P job, big valves, good cam etc. Stock 4AC is weak over 4500 RPM due to poor head/intake/exhaust header design but all these can be improved. I don't know exactly are 4AC internals good for continuos 6000+RPM or not (mine was "tested" over 7000RPM and survived, 100% stock engine).I already knew you could achieve it with a 4AC, but with a 16v head it's easier. ![]() 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
05-25-2006, 12:49 PM
USA New Member
Oh no, I personaly never tried to achieve 170 hp from 4A engine
![]() It's too early for me, I'm focused on mild modifications. |
05-28-2006, 10:17 PM
USA New Member
Yes the 4AC is just a sohc extremly restrictive 4AGE. The 4AGE is the free flowing head while the 4AC is a block of little holes. With a larger carb alone I've seen dyno gains of 12-16 (16 after fuel/air mix was down) whp. This is on a average size aftermarket progressive webber carb. I'm still trying to learn more about Megasquirt and other standalone systems to run a engine. I think it would be cool to have a ITB 4AC done right. I'll post some pics of the coupe.
New Member from Ireland | chrisae86 | 7 | 6,385 |
06-01-2020 12:01 PM Last Post: decryphe |
New member in Canada | Frs_ken | 2 | 4,357 |
03-18-2019 01:04 AM Last Post: kazi |
new member | hedgehogdodger | 1 | 3,737 |
01-19-2019 11:30 PM Last Post: banpei |
Old member, new account | Power_uP | 6 | 7,286 |
11-29-2017 05:14 PM Last Post: Hama86 |
New Irish member | JDMfrank | 6 | 7,995 |
10-15-2014 03:46 PM Last Post: JDMfrank |
