Under bucket shims
05-27-2008, 09:03 PM
Under bucket shims
I've managed to find a set of cam followers that are of the under bucket type, unfortunately the chap selling them does not have any shims Huh
Can anyone tell me how the shims actually fit into the buckets ?
Thanks
05-27-2008, 09:13 PM
Under bucket shims
Hmm...most guys use the yaris buckets, which are machined to a certain thickness (meaning: no shims). If you have these, you should see a little protrusion on the inside of the shim where it contacts the valve stem.
Havent seen any actual shim-under-bucket type valve lifters on the forum in all my years here.
05-27-2008, 09:40 PM
Under bucket shims
R.hellenbrand uses them. And so will I in my new head. Problem is you need to buy the cams and then measure it with the standard shims. After that buy 2 or 3 yaris buckets. Check the size and then order the rest according to the measurement.
05-27-2008, 10:46 PM
Under bucket shims
what are you guys talking about? Undecided
05-27-2008, 11:42 PM
Under bucket shims
Eric Wrote:what are you guys talking about? Undecided
lols, sounds confusing huh? they are talking about the shim less bucket for the yaris motor. i think they confused the poor guy.
well for the original poster of this post, you might want to hit up the manufacturer of the bucket kit ie...toda. if its a toda kit contact them. gl.
te72 wagon
ae86 levin coupe project
[Image: AEU86 AE86 - Under bucket shims]
05-28-2008, 01:23 AM
Under bucket shims
http://www.club4ag.com/faq_and_tech_page...uning.html
05-28-2008, 01:58 AM
Under bucket shims
Think of thems as nipples but on the inside!!.
From what I gather you need to know the tollerances you need & then order the buckets.
05-28-2008, 05:16 PM
Under bucket shims
1SZ Toyota 4 cylinder engine uses valve buckets of a one piece design. Each bucket is machined to a specific thickness. This allows a single piece (NO bucket AND shim), that is considerably lighter then the stock units. These lifters(one piece buckets) are the same diameter as the 4AG bucket, so they fit perfectly.
There is a alleged problem with using 1SZ buckets... extreme camshafts may cause them to distort.... I've heard of this.... but as of yet failed to see any.
When I was working for Cyberauto... we recommend a set of 8 of the smallest buckets to use for sizing, and then once you had your sizes verified, you'd order the 16 you would need.
Dan -
05-28-2008, 07:12 PM
Under bucket shims
hey already saw a 181 hp 4age 16v with them. No problem. I am gonne ask some toyota dealers to check if they maybe have some I could borrow!
05-29-2008, 04:16 AM
Under bucket shims
Part# size in mm
13751-23030 5.12
13751-23040 5.14
13751-23050 5.16
13751-23060 5.18
13751-23070 5.20
13751-23080 5.22
13751-23090 5.24
13751-23100 5.26
13751-23110 5.28
13751-23120 5.30
13751-23130 5.32
13751-23140 5.34
13751-23150 5.36
13751-23160 5.38
13751-23170 5.40
13751-23180 5.42
13751-23190 5.44
13751-23200 5.46
13751-23210 5.48
13751-23220 5.50
13751-23230 5.52
13751-23240 5.54
13751-23250 5.56
13751-23260 5.58
13751-23270 5.60
13751-23280 5.62
13751-23290 5.64
13751-23300 5.66
13751-23310 5.68
Dan -
  Bucket seat prices gh0st 5 2,904 01-23-2022 11:44 PM
Last Post: AlexKTM
  Downpipe + exhaust under 102 db DidiDex 1 3,847 09-12-2019 10:45 PM
  Shims 20V Blacktop CHOPKIN2 3 4,990 12-23-2017 11:07 PM
  Alternative Supplier for 4AGE 20V valve shims... jondee86 6 10,521 04-01-2014 11:00 AM
Last Post: Project D
  Where to get oversize 20v shims? PazzaAE86 4 6,082 10-28-2011 05:34 PM
