Underbucket shims
08-16-2008, 08:48 PM
Underbucket shims
Anyone have a clue what to use ?
I have seen a 'top hat' type used that sits on the valve stem and I know TRD do a spring retainer that uses a flat 9.5mm shim that fits in the top. I think the TRD ones use non standard collets (keepers) also. Any other issues with the TRD type ? thanks tc An analogue brain in a digital World |
08-16-2008, 09:10 PM
Underbucket shims
Yaris ones. Yaris (vitz?) has the same size. Its well known in japan and also found on club4ag. I am building an engine which also has it. Just buy the cams. Measure with the original buckets than buy one yaris. Measure what you need and order form toyota.
08-16-2008, 10:09 PM
Underbucket shims
Thanks for the reply. I should have made it clear that I already have the underbucket cam followers, just need to sort the shims now
08-27-2008, 05:37 AM
Underbucket shims
Consider using the Yaris under bucket shims, these are one piece and are much lighter.
08-27-2008, 10:32 AM
Underbucket shims
Totta - The set up you have described sounds identical to the shim/bucket set up found on the late spec 3sgte (and possibly other engines)
Its an under bucket arrangment with a small shim that sits in the spring retainer recess under the bucket - the shim is about 10mm across or there abouts from memory. The shims can be found on 1994 onwards SW20 turbo or a ST205 GT4. Sounds like you have confirmed what I stated a whle back that the under bucket arrangement on the late 3SGTE will also fit the 4AGE head. Your looking at about £40 for a full set of shims for the head - Toyota can supply them in every size but you will need to get 1 first so you can work out the tolerances and what you need for the rest of the 16 valves. I will see if I have any spares kicking around in the garage from the last gte rebuild i did. ![]() http://www.eight-six.co.uk - read the blog! UK AE86 Forum - http://www.phpbber.com/phpbb/index.php?m...ghtsixcouk |
09-22-2008, 04:28 AM
Underbucket shims
Try contacting friends on this board to get you the shim sizes you need for your head adjustment.
Shims 20V Blacktop | CHOPKIN2 | 3 | 4,986 |
12-23-2017 11:07 PM Last Post: oldeskewltoy |
Alternative Supplier for 4AGE 20V valve shims... | jondee86 | 6 | 10,516 |
04-01-2014 11:00 AM Last Post: Project D |
Where to get oversize 20v shims? | PazzaAE86 | 4 | 6,077 |
10-28-2011 05:34 PM Last Post: Project D |
20v Blacktop Shims | PazzaAE86 | 2 | 4,506 |
10-18-2011 04:31 PM Last Post: PazzaAE86 |
Brake pad springs&shims | Apolan | 7 | 8,112 |
08-27-2010 02:21 PM Last Post: Apolan |
