Upgrade transmission or what can I do?
06-11-2010, 08:55 PM
First off all, people allways talks about the stock transmission are too weak and can not support 200hp. Can someone please tell me what exatly the problem is? and mayby upload some pics of the broken parts.
The reson why, is I newer have any problem with my transmission, but my engine was stock and now I'm building a new 200hp+ race engine. I have thought swapping an other transmission, like the BMW M3, Mazda MX5/Miata or even a Ford Sierra 4 or 5 speed. Who have tryed one of these swaps? I know some tranny's break because of the 2 axels move away from each other, and then the bearings and transmissioncase breake. This problem will be eliminated when fitting a straight cut gear set, but I don“t know who make those for AE86. Straight cut, I mean like the reverse gear, not as the TRD gear set. At last, which gearkits are available for AE86??? Project AE86 now begun. Cars I have owned: Toyota Starlet EP91 1,3 16v Turbo, 200hp Toyota Starlet EP71 1,3 12v Sport Mercedes 207D camper, 1977. Toyota Starlet EP70 with a 174hp Silvertop 20v See video here: http://videos.streetfire.net/search/Star...079edc.htm Toyota Corolla AE101 with a 164hp Silvertop 20v. (Evolution bodykit and candycolor paint). Volvo 240 2,1 (The only car I have maked money on). Toyota Corolla EE90 (my first car) |
06-11-2010, 11:06 PM
The stock unit should support 200HP. As long as its in decent shape.
06-11-2010, 11:51 PM
Quaife make straight cut gear set
![]() but that kind of gearbox is realy noisy (not realy an issue on race car anywhay) but on N2, many guys use OEM Gearbox with different gearset (like TRD gearset) without any problem. maybe they are refurbished sooner than a "street car" but more because of the aggressive use, than the Horse power passing thought it |
06-12-2010, 12:40 AM
Abuse kills gearboxes, not horsepower. Dumping the clutch, driving
over kerbs with power on, anything that puts sudden and high torque loads on the gears. Helical/spur gears have only a few teeth in contact, and the teeth can only sustain a certain load before they break off. Sudden, high impact loads can break them. Repeated high torque loads above design, will lead to fatigue cracking and breakage. Continuous high torque loading with high temperatures or poor lubrication will lead to surface fatigue, cracking, pitting and failure. As said above, if you use the clutch with some consideration, and avoid kerb jumping etc., the T50 will handle 200 hp from your high revving, but relatively low torque engine ![]() and you should be fine. Cheers... jondee86 |
06-12-2010, 12:41 AM
The sierra box swap has been done loads of times in Rally cars & works very well, Fensport used to sell the bell housing.
http://www.fensport.co.uk/Parts/Model_3/Category_3/ If you are interested in going this route, PM me as I think a mate of mine in Ireland has one & the clutch etc sitting round since he sold his car. I was going to buy it but I can only get the sierra cosworth box here Australia with is a different fit. http://www.ae86irl.com/forum/showthread....a+fensport There are adaptors around for W series boxes out of the Supras, RX-7 & a few others I cant think of right now. An 86 is for Life, not just for Christmas |
06-12-2010, 10:37 AM
So its actually the gearset that breaks?
That strange, because Toyota's FWD trannys can handle 7-8 times as much horsepower and 4 times more torque, than its suposed too, even with M/T drag slicks and even shifting @ 9500rpm. Of couse on a drag strip, not a bumpy road :wink: I know about the Quafe gearset, but some people have trouble with these, they stuck in gears. And its a pretty expensive upgrade. I thought I have bought a Ford Sierra 4 speed dogbox, but when I got it opened, it was a stock Ford tranny, with a 4AG bellhousing ![]() Also the quaife dog gearset can not support more than 185hp, and only 7000rpm or so. Who else beside quaife and TRD sells gearsets for our cars? And I don't care about the noise, I think its one of the sweatest sound ind the world such a race transmission. Project AE86 now begun. Cars I have owned: Toyota Starlet EP91 1,3 16v Turbo, 200hp Toyota Starlet EP71 1,3 12v Sport Mercedes 207D camper, 1977. Toyota Starlet EP70 with a 174hp Silvertop 20v See video here: http://videos.streetfire.net/search/Star...079edc.htm Toyota Corolla AE101 with a 164hp Silvertop 20v. (Evolution bodykit and candycolor paint). Volvo 240 2,1 (The only car I have maked money on). Toyota Corolla EE90 (my first car) |
06-12-2010, 11:24 AM
Yaris 1.3 xp9 Yaris 1.0 p1 Mercedes citan weekend driver 1985 AE86 |
06-12-2010, 01:03 PM
Have a look at the Quaife[u:d318775f0c] pro [/u:d318775f0c]Ford type 9 'box as the shafts rotate on needle roller bearings it can stand higher revs than the normal Quaife set.
Expect to change the ring and pinion to something like a 4.8 or ideally a 5.375 to make the most of a close ratio box. Dogboxes are nice but the dog rings are expensive and need changing at regular intervals. An analogue brain in a digital World |
Can Wing Mirror Glass be Replaced? | chrisae86 | 1 | 1,676 |
03-05-2023 09:34 PM Last Post: Ivan141 |
Gearbox mount and transmission mount | gh0st | 9 | 4,605 |
05-08-2022 03:28 PM Last Post: totta Crolla |
Can you convert your 86 back too the original state? | gh0st | 7 | 3,878 |
Can you seperate trueno kouki bumper lights into zenki bumper lights? | gh0st | 17 | 10,479 |
12-19-2021 11:58 PM Last Post: gh0st |
Can you identify this wheels? Will they fit AE86? | Ryo | 8 | 12,084 |
