VVt trigger on a silvertop.
06-24-2008, 10:11 PM
I am just about to fit a 20valve silvertop, I am running a standalone ecu, what way do I trigger the vvti? I know it has a connector for it on the head above the exhaust manifold..
Any info would be great.
Ivan
1972 MG Midget - AE86 Engine, Ford Anglia Axle - Escort LSD - Live the Dream!!1
06-24-2008, 11:38 PM
i think,12 volt and a massa(-) trigger from the ecu,just on and off i can check it on my blacktop tomorrow
[Image: AEU86 AE86 - VVt trigger on a silvertop.]
06-24-2008, 11:43 PM
just from memory..
- never enabled with water temp < 60C
- enable at 4000 rpm
could be off a bit, but its based on both the temp and the rpm.
06-26-2008, 01:09 AM
It has two wires from it from, I take it one is 12 volt supply and the other will activate when switched to ground. I can trigger from various things on the ECU, just wondering if there was any benefit from triggering early. Heard something about Honda V-tecs making more power with Vtec controllers and vtec switching early.
Ivan
06-30-2008, 04:19 AM
I tried switching +12 and ground onto the solenoid, nothing happens, is this correct?
Cheers
Ivan
07-01-2008, 12:58 PM
Got it sorted, It does use a 12v trigger, it was just stuck, removed it from the head and cleaned it. It should also measure 13 ohms.
Ivan
  20v Silvertop - New Haltech ECU & Couple of questions 20valver 10 3,087 05-26-2024 07:40 PM
Last Post: totta Crolla
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 14,202 07-18-2019 03:52 PM
  20v silvertop idle issue AlexFourTwenty 3 5,412 12-24-2017 03:27 AM
Last Post: AlexFourTwenty
  stock injector deadtime for 4age 20v silvertop/blacktop injector ditn 1 6,122 02-20-2016 11:48 AM
  20V VVT on standalone ECU fax0815 5 10,407 08-09-2013 09:27 AM
Last Post: rene
