Vacuum Sensor/line hook up help.
04-17-2008, 09:22 PM
Yah I am. Everything is USDM on my char except the Engine Harness/Engine/Tranny/ECU/Cluster, Which is Japanese.. I also had to order a igniter I had it cross refferenced to a USDM Mr2 with a 4AGZE, I think it was. The plug matches up and all But one of my main things is now My car will crank but there is no spark coming from the Coil... Im not sure what is causeing it.. Im going to look a few things over in the next few hours if anyone knows maybe if there is a wire that needs to be rewired of what...
And as for that square plug with a single wire coming out. That is for the TVIS? So I need to connect that to the TVIS? How do I do this and where do I connect it?? |
Messages In This Thread |
Vacuum Sensor/line hook up help. - Nanaki - 04-10-2008, 08:29 AM
Things you don't need.... - jondee86 - 04-10-2008, 09:34 AM
So many questions... so little time :)) - jondee86 - 04-17-2008, 09:00 AM
[] - Nanaki - 04-17-2008 09:22 PM
Do you wash and wipe ?? - jondee86 - 04-20-2008, 08:50 AM
Don't loop the idle-up tubes.... - jondee86 - 04-20-2008, 09:03 AM
Lambda sensor wiring | sam3007 | 10 | 4,257 |
fuel line hose from the pump | Wikizz | 4 | 5,988 |
US-spec vacuum hard lines | LordTD | 2 | 4,969 |
04-27-2015 07:18 PM Last Post: Project D |
AE86 Engine Coolant Temp Sensor | izanagi | 8 | 20,225 |
brake line leaking - how to fix ? | MC_JP | 2 | 4,303 |
04-28-2014 09:47 PM Last Post: MC_JP |
