Vacuum Switching Valve Question
07-27-2007, 03:04 AM
mzdafrk Wrote:thanks for the explanation.
It was just the master cylinder, replaced it this morning, and all is better, just took some time and bleed all the brakes really well, and I have better brakes than I ever had before.
It was weird, it didn't act like a blown master cylinder, but I was loosing brake fluid, so It had to be the master or a leak. But couldn't find fluid anywhere on or under the car. So went for the $25 shot in the dark and it worked, I was leaning more towards the Booster. At least it is fixed, and I can stop again.
If it was loosing fluid you should have been able to find the leak. Or it was leaking out the rear of the M/C into the brake booster... was it wet there?
Andrew
Messages In This Thread
Vacuum Switching Valve Question - mzdafrk - 07-26-2007, 04:54 AM
[] - mzdafrk - 07-27-2007, 02:00 AM
[] - assassin10000 - 07-27-2007 03:04 AM
[] - mzdafrk - 07-27-2007, 03:09 AM
[] - evfan42 - 07-27-2007, 07:46 AM
[] - mzdafrk - 07-27-2007, 07:49 PM
  4AGE Valve Buckets Scored Steller Engineering 2 882 10-06-2023 05:34 PM
  20 Valve Blacktop smoking after engine flush - why? RolanTHUNDER 2 1,348 11-30-2022 12:09 PM
Last Post: RolanTHUNDER
  Switching diffs for disc brakes? trippin 6 2,629 07-08-2022 03:35 AM
Last Post: trippin
  HKS valve springs totta Crolla 3 2,160 05-25-2022 10:24 PM
  Valve clearance leon205gti 7 8,573 11-25-2016 03:24 AM
