Vacuum plenum tank
10-06-2008, 11:18 PM
Vacuum plenum tank
Hi guys
Could you help me find a vacuum plenum for my ITB 16v conversion? I know arpadal has bought one - but I cannot find one? Huge plus if located in EU!
- Thanks, Niels
10-07-2008, 12:12 PM
Vacuum plenum tank
http://www.aeu86.org/viewtopic/golden-ea...lden+eagle
http://www.aeu86.org/viewtopic/vacuum-ta...lden+eagle
10-24-2008, 05:58 PM
Vacuum plenum tank
Make one yourself - very easy to do.
Get an old 16v fuel rail - get a tap and run a thread into the 4 injector holes on the fuel rail. Got to a hardware store and get 4 threaded hose barb fittings.
The remaining holes can be tapped for other things like the map sensor outlet, brake booster, FPR vaccum feed etc. All very very easy to do, job done and looks neat as well. If you dont have the 16v injectors as you are running 20v ITB's it also means that you can mount this where the stock fuel rail sits.
Cheers
James
[Image: AEU86 AE86 - Vacuum plenum tank]
http://www.eight-six.co.uk - read the blog!
UK AE86 Forum - http://www.phpbber.com/phpbb/index.php?m...ghtsixcouk
10-28-2008, 02:36 AM
Vacuum plenum tank
I have one if you want it, I got it from Golden eagle in the states and bought all the fittings aswell, I fitted a silvertop so don'y have any need for it .
Cheers
Ivan
1972 MG Midget - AE86 Engine, Ford Anglia Axle - Escort LSD - Live the Dream!!1
  bubbles in expansion tank? fax0815 5 6,201 04-28-2017 04:57 PM
Last Post: fax0815
  US-spec vacuum hard lines LordTD 2 5,217 04-27-2015 07:18 PM
Last Post: Project D
  Cylinderhead ventilation - greasy plenum... Lt86 9 13,196 04-02-2015 10:41 PM
Last Post: Lt86
  Fuel Tank Modification apardal 1 5,661 08-11-2014 06:59 PM
  Pressure gathering in fuel tank Apolan 9 15,457 05-18-2014 06:18 AM
Last Post: chenfon
