Valve clerance for 4age 16v
01-23-2007, 09:47 PM
Hi guys im looking to do a shimless conversion from 1SZFE to my 4age 16v red-top engine. Since the under-bucket shims is crazy expensive ill go for 1SZFE conversion.
I will use 272deg 9mm camshaft(int\ext) and im looking for valve clerance to use these camshafts. I have a Toyota repair manual and it say the valve clerance should be: Intake: 0.006in to 0.010in Exhaust: 0.008in to 0.012in But these clerance are for stock camshaft. I got also a TRD Bible wich set the clerance for a 272deg 7.5mm lift to: Intake: 0.005in Exhaust: 0.007in But i want to be sure of wich clerance I can use for my type of camshaft, someone know a clerance to be used for a 272deg 9mm lift camshaft(int\ext)? Thank a lot Ugo |
01-23-2007, 10:07 PM
you 'll have to find the installation sheet of your cams my friend ...
AE86 FANATIC!!! |
01-23-2007, 10:56 PM
only know is that they should be less than the 7.5 lift, but you probably knew that already
hope you find the right info |
01-24-2007, 12:00 AM
delange thats not true, I had 8.5mm lift on my exhaust cam and 9 mm lift on my intake.
http://www.catcams.be/800x600/prod01Alis...71051xx.js I had teh second one. (have them now ones more) They can be fitted and work fine! valve info! http://www.catcams.be/datafiles/docs/spr...051xx1.htm Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
01-24-2007, 12:14 PM
robokill Wrote:delange thats not true, I had 8.5mm lift on my exhaust cam and 9 mm lift on my intake. I ment that the clearence schould be less, cause of the higher lift, correct me when I'm wrong |
01-24-2007, 10:27 PM
I have look carefully in the box, no paper at all about valve clerance.
These cams are Toda racing 272deg 9mm lift. If i cant find the right valve clerance specs i think i will go for the N2 valves clerances specs and see what happen. |
01-30-2007, 08:51 PM
On my Web cams(294 grind)... I'm using stock specs...
cold intake - .15mm to .25mm exhast - .20mm to .30mm I'm the overzealous type... so I made ALL intake clearances .2mm and all exhaust .25mm each is dead on in the middle of the spec by matching all clearances..... in theory... all lifts/durations will then be identical when measured at the valve Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
01-30-2007, 10:42 PM
Clearances are related to the material which the cam is made and not its lift or duration.
HKS states that for 256/264/272 camshafts the clearances are the following: Intake 0.25mm +/- 0.03mm Exhaust 0.30mm +/- 0.03mm Toyota states something different that I can't find right now! Best regards |
4AGE Valve Buckets Scored | Steller Engineering | 2 | 925 |
20 Valve Blacktop smoking after engine flush - why? | RolanTHUNDER | 2 | 1,438 |
HKS valve springs | totta Crolla | 3 | 2,244 |
Cusco Powerball Headers on a NA 4AGE 16V? | JDMitch | 11 | 20,991 |
05-01-2021 10:09 PM Last Post: Ivan141 |
4AGE 16V engine overheat when at high speed | chenfon | 32 | 21,918 |
