Valve springs length
04-03-2013, 10:44 PM
hi,
Can anyone tell me the length of valve springs for 4AGE 16v, from Toda, Supertech or HKS ?
My question is because the valve springs of the Peugeot 206 Gti 1.6 have exactly the same dimensions has that the original ones from 4AGE, exept the lenght ,that is more 3 mm on the Peugeot.
Vitor
04-04-2013, 08:36 AM
hi vitor
to give a correvt answer on this you to tell what you want to do, but why not use springs made fro the tu5JP4 engine ?
you can get them any where
04-04-2013, 12:32 PM
Do you know the poundage spec. of the Peugeot springs ?
As the Tu engine is 8 valve the springs are likely to be too
heavy poundage for a 16 valve.
04-04-2013, 07:41 PM
The Toda springs are 41+mm free length
Also... you need to check at one point coil bind occurs. A 3mm taller spring MAY bind earlier... check using the FSM for installed height, and then add the amount of lift your from your cams to see if they will bind.
Also check for installed spring load, as well as spring load @ full lift.
Dan -
  Rear arm length totta Crolla 7 1,515 06-05-2024 08:53 AM
Last Post: totta Crolla
  4AGE Valve Buckets Scored Steller Engineering 2 1,063 10-06-2023 05:34 PM
  20 Valve Blacktop smoking after engine flush - why? RolanTHUNDER 2 1,651 11-30-2022 12:09 PM
Last Post: RolanTHUNDER
  HKS valve springs totta Crolla 3 2,480 05-25-2022 10:24 PM
  Valve clearance leon205gti 7 8,980 11-25-2016 03:24 AM
