Valve springs length
04-03-2013, 10:44 PM
hi,
Can anyone tell me the length of valve springs for 4AGE 16v, from Toda, Supertech or HKS ? My question is because the valve springs of the Peugeot 206 Gti 1.6 have exactly the same dimensions has that the original ones from 4AGE, exept the lenght ,that is more 3 mm on the Peugeot. Vitor |
04-04-2013, 08:36 AM
hi vitor
to give a correvt answer on this you to tell what you want to do, but why not use springs made fro the tu5JP4 engine ? you can get them any where |
04-04-2013, 12:32 PM
Do you know the poundage spec. of the Peugeot springs ?
As the Tu engine is 8 valve the springs are likely to be too heavy poundage for a 16 valve. An analogue brain in a digital World |
04-04-2013, 07:41 PM
The Toda springs are 41+mm free length
Also... you need to check at one point coil bind occurs. A 3mm taller spring MAY bind earlier... check using the FSM for installed height, and then add the amount of lift your from your cams to see if they will bind. Also check for installed spring load, as well as spring load @ full lift. Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
Rear arm length | totta Crolla | 7 | 1,273 |
06-05-2024 08:53 AM Last Post: totta Crolla |
4AGE Valve Buckets Scored | Steller Engineering | 2 | 947 |
20 Valve Blacktop smoking after engine flush - why? | RolanTHUNDER | 2 | 1,464 |
HKS valve springs | totta Crolla | 3 | 2,273 |
Valve clearance | leon205gti | 7 | 8,758 |
11-25-2016 03:24 AM Last Post: oldeskewltoy |
