Wanted: 3-rib engine repair manual
09-06-2022, 03:15 PM
Does anyone happen to have a 4age engine repair manual PDF for the early 3-rib block? All I can find online are the 87 and later manuals that only refer to the 42mm crank and floating pistons.
I believe it should be covered in the 1983 manual for all A-series blocks, which I cant find anywhere. FABRICA MI DIEM, PVNC! |
09-06-2022, 05:15 PM
I also only have the manual dated 1987 in PDF form. I'm not sure which paper version I have in the shurgard, but if it's an earlier version you can borrow it. I'll check next time I'm there.
09-06-2022, 05:26 PM
The Doctor just messaged me, he has the actual 1983 FSM I'm looking for, only paperback, not PDF.
I'll try to scan it if it's not too much hassle at work Verstuurd vanaf mijn Pixel 4a met Tapatalk FABRICA MI DIEM, PVNC! |
09-06-2022, 09:56 PM
(This post was last modified: 09-06-2022 09:57 PM by banpei.)
Maybe you can just scan the pages that are different?
I'll still have a look which version I own. Maybe I can help out with scans as well. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
09-07-2022, 06:04 PM
I have a 1986 AE86 paper manual... can make a few scans if you'd like....... likely just jpg
Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
09-08-2022, 08:25 AM
If it's relevant to the 40mm crank and perhaps the piston pin replacement procedure, that would be much appreciated Dan.
09-09-2022, 07:46 PM
As far as the wrist pin.... it says use SST. Typically a 1st gen 4AGE requires a rod heater to properly fit the wrist pin.
As far as 40mm crank info: Main journal diameter: 47.985mm - 48.000mm(1.8892" - 1.8898") Rod Journal diameter: 39.985mm - 40.000mm(1.5742" = 1.5748") Maximum runout: .06mm(.0024") Maximum taper/out of round: .02mm(.0008") Main journal clearance: .012mm - .039mm(.0005".0015") Limit .10mm(.0039") Rod journal clearance: 0.020mm - 0.051mm (.0008" - .0020"). limit .08mm(.0031") Thrust clearance: .02mm - .22mm(.0008" - .0087") limit .30mm(.0118") Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
Play between steering column and intermediate shaft after manual rack sonversion | DaLanZhu | 5 | 6,890 |
Rear arch repair panels | TomRich | 4 | 6,798 |
08-30-2018 09:19 PM Last Post: zenki |
TRD multi-ECU manual | Two Sheds | 10 | 19,828 |
07-12-2017 12:21 AM Last Post: jondee86 |
4A-GTE 7-rib smallport | nyberrg | 5 | 6,270 |
05-24-2017 09:24 PM Last Post: krullibull |
AE101 4AGZE workshop manual | bozu | 1 | 7,111 |
04-04-2017 10:52 PM Last Post: hachirokkos |
