Weak Grounding problem with Temperature sensor
07-29-2005, 12:25 AM
Hi Guys,
Was finally told the reason to the problem with my temp sensor not working. The sensor does not have a good ground!! If I touch a wire on the sender, and connect it with the negative terminal of the battery, the gauge will work.
Can anyone tell me why my ground is bad? What should I look for to fix this without soldering a wire to the sensor and running it to the battery?
Thanks for your help
Trueno for sale!
07-29-2005, 07:51 AM
You could try finding the ground wire that is originally connected to it and check where that goes. It's probably a loose contact somewhere. But the easiest thing to do would be to solder a wire with one of those crimp contacts that you can mount under a screw, and then attach that to a screw behind the dash going straight into a solid piece of chassis. (around the fuseboxes for example, or just use one of the grounds there.)
  Lambda sensor wiring sam3007 10 4,257 05-23-2022 10:00 PM
Last Post: The Doctor
  Weak spark, doesn’t start. AlexFourTwenty 4 15,094 12-12-2017 03:35 AM
Last Post: AlexFourTwenty
  Water Temperature Instrument not moving - Sender Gauge Hama86 8 7,509 12-06-2017 06:48 PM
  Wheel Bearing Temperature Super86 5 6,628 09-29-2014 12:26 AM
Last Post: jondee86
  AE86 Engine Coolant Temp Sensor izanagi 8 20,225 09-06-2014 05:47 PM
Last Post: izanagi
