Webber DCOE 45mm for 200hp
05-17-2013, 11:30 AM
As subject states guys these are the carbs i bout with a smallport manifold. off a running engine so they re a bolt on ready to start already jetted for 4age motor.
for those remeber last time i was asking which carbs i should get for backfires and noises i am sure these will do. ANY Way Lets get to the Point. Now that i have the carbs i need to know what i need to try get to 200hp The is engine fully N/A currently EFI. it is going to be running a 4k modified dizzy. Or some ppl on here may have awesome carbed 4ages that have such power and would like to share they re Specs? Many thanks- |
05-17-2013, 11:44 AM
To get to 200+hp I would recommend you get yourself a nice F20C / 3SGE-Beams engine...
Running that kind of hp on a 4age, especially one with carbs and a distributor off a 6k rpm max starlet engine is outside the realm of realism. Getting that out of the 4age will cost you more than the abovementioned engines, and be a lot less reliable/driveable. Best you read the engine builds on the forum to get a realistic picture of what is possible for a given budget. I'd say 160hp is more than ambitious enough in your case, but I'm just guessing. FABRICA MI DIEM, PVNC! |
05-17-2013, 12:29 PM
Hi man it says (Try to get to 200hp) ive been googling around doesnt cover much on carbs just ITB and lots of swap engine... the thing is i hate wires i just want a neat engine bay. 3SGE is ugly heavy and sounds like shet. but hey 160hp is not bad so il gain another 30hp whats needed for that? thanks
05-17-2013, 03:08 PM
I normally don't do this but for once I can't resist.
USE THE SEARCH FUNCTION! This been covered dozens of times, carb or efi makes slim difference in final power figure when set up right. AE86 ex-daily |
05-17-2013, 09:01 PM
I think it would be a good idea to do some months/years research before you even start building a 200hp 4a-ge.
And why would you go for 200 horses ? Wouldn't it be nice to have a bit torque also ? A good usefull engine, doesn't only have HP... it needs also some torque. I run some 40mm dellorto's on a tuned 4a-ge 16v, i just love the sound of them and i love the looks and the smell of the old carburators. But i think if you want some good smooth and high horsepower engine... it isn't a good idea. And why the .... you ask???? ''which carbs i should get for backfires and noises '' Backfires ? http://bruutt.blogspot.nl/ Projects: Lancer evo 4 rs, ae86 drifter, carina ta60 4a-ge & ae82gt twin cam.. |
05-17-2013, 09:07 PM
for a bit of discussion
why do you take carbs over injection? ![]() |
05-17-2013, 09:57 PM
Buy this engine:
http://www.ebay.co.uk/itm/Toyota-4AGE-Ra...27d2c453ba For backfires you could run it really lean but buy some spare pistons when you buy the engine ![]() ![]() ![]() An analogue brain in a digital World |
05-17-2013, 10:38 PM
kpretro, if you want a nice engine with no high cost you need the following:
- be able to built it yourself - have a budget of between 1000 -> 2000 euro to make it something - patience - chance to break your engine If the above are all A oke! then no worries. Except the search function I will just add another hit to the search engine. - Take the engine apart (completely) - Do the standard headwork (see TRD guide its not perfect but it will do alot of good) - Change valves / guides / springs / lifters (use Yaris / Vitz) - My recommendation is a nice set of Catcams 4age cams high lift not too exceed 288 duration - Clean the bottom end of your engine. (smooth it out) (get it washed) - All new washers / seals / oilpump / waterpump / bearings Build it up properly. Get it to a tuner and setup. See how much it makes. Don't forget to post a full build guide ![]() Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
05-18-2013, 12:41 AM
kpretro84 Wrote:As subject states guys these are the carbs i bout with a smallport manifold. off a running engine so they re a bolt on ready to start already jetted for 4age motor. How much money do you have...... SERIOUSLY... how much do you have? Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
05-18-2013, 12:46 AM
if you have no expense with engine building
buy a engine from a engine builder cheaper in the long run but 200 hk is expensive head work, you have to fit bigger valves to get over 180 to 190hk big lift cams again machining off head and followers off shim under buket type but it is a +10k euro engine you are starting on so if this you first engine forget it, you just get disappointed |
