What brake fluid are you using in your hachi ?
06-01-2005, 03:16 PM
Hi guy's
what brake fluid's are you using in your hachi ? and i also would like to ask how much do i need for brake system and clutch thanks 85' AE86 GT coupe lifetime project since 2005 |
06-01-2005, 07:36 PM
I use Ate DOT 4 oil, but a cheap DOT 5.1 is also nice.
Taking the bleeding procedure and some general sloppyness in account you should just get 1.5 liters. FABRICA MI DIEM, PVNC! |
06-02-2005, 08:53 AM
i bought 1 litre and i still have almost half left. i have filled both the clutch and brakes. all bled.
06-02-2005, 09:00 AM
There you go...I used up some more the first time I filled my system cause the brakes would not bleed the air out properly, and I rebuilt the calipers and master cilinder at 2 different occasions. 0.5 liters sounds about right, it takes the same amount on my volvo which is easy to bleed the brakesystem on.
I'm getting myself 4 new bleedvalves tomorrow so hopefully that will fix the problems with my brake system. FABRICA MI DIEM, PVNC! |
06-02-2005, 10:19 PM
Ivan141 Wrote:I use Ate DOT 4 oil, but a cheap DOT 5.1 is also nice. dot4 is cheaper than dot 5.1.. dot 5.1 is a full synthetic brake fluid.. i use Castrol dot 5 synthetic brake fluid.. Toyota Starlet 1994 Mitsubishi Space wagon 2.4 1999 ex Ae86 owner |
06-03-2005, 09:02 AM
I know DOT 4 is cheaper, but for street use I wouldnt exactly use expensive DOT5.1 oils...cheap ones work fine though..
Isnt synthetic DOT5 fluid bad for your brake system unless you flush it very often? If I remember correctly it isnt hygroscopic, so when water eventually gets into the brakesystem (and it will), it will stay together in one place and cause rusting brakelines.. FABRICA MI DIEM, PVNC! |
06-03-2005, 09:21 AM
i wouldnt put in dot5 for daily use.. maybe for trackdays, then replace it with dot4 or 5.1
06-03-2005, 09:39 AM
http://www.promat.hr/zax/AE86/AE86-560_small.jpg
Mintex racing oil. No DOT specifications. Say goodbye to boiled brake oil. I use it on the track and i'm very satisfied. 1l = 22€ Drifting - best fun you can have in your car with your pants on! |
06-03-2005, 10:14 AM
Ivan141 Wrote:If I remember correctly it isnt hygroscopic, so when water eventually gets into the brakesystem (and it will), it will stay together in one place and cause rusting brakelines..DOT 5 is silicone-based and yes - not hygroscopic. But there is no way to find water in brake system - unless you fill your brake master cylinder reservoir with water :-) The only common problem with DOT 5 is uncompatibility with DOT 3, 4, 5.1. |
06-03-2005, 10:49 AM
If you will not find water in your brake system, then why does the usual brakefluid deteriorate due to water it absorbs?
PWR light issue and no brake fluid after winter storage | magpie | 10 | 2,782 |
Can you convert your 86 back too the original state? | gh0st | 7 | 3,036 |
Build your own adjustable fuel pressure regulator ;) | oldeskewltoy | 8 | 21,205 |
What suspension set up are people using? | kazi | 8 | 8,284 |
07-06-2017 05:26 AM Last Post: headrush |
How would/have you rebuild your 4age? | joaotcgt | 6 | 9,044 |
07-21-2015 10:40 AM Last Post: mad.matt |
