What efi is compatible for swap on a carburator
02-09-2010, 09:55 PM
I have a corolla i just bught but im tryin to go from carb to EFI what do i need to do.. besides buyin an engine lol... please help!! what intake system is compatible to it and what ecu do i have to use?
thanks |
02-09-2010, 10:18 PM
? well AE86 are originaly fitted with an EFI system... so if you got carbs it was custom made - so you wouldn't need to get a new engine just the matching EFI system... alittle more info on your car would help
AE86 ex-daily |
02-09-2010, 10:20 PM
well is a 84 corolla.
02-09-2010, 10:26 PM
well let's try again
as you are from San diego I guess it's USDM so is it an SR or GT version? or post a pic of your enginebay AE86 ex-daily |
02-09-2010, 10:29 PM
is a sr version and is a usdm
02-09-2010, 10:44 PM
ok nevermind!! the engine is a 4a-c, i was just doin reseach at my school. so would a 4a-ge intake manifold fit on a 4a-c head?? and what do i need to turn it into fuel injected?? my whole purpose is to turbo it.. so what do i need? sorry im new to the corolla scene.
alright I get it now... well you could get the whole twincam setup then engine incl. loom and ECU I'm not sure if you'll benefit of fiting an EFI system to your SOHC head... maybe the twincam head will fit but I'm not sure about that. As for aftermarket EFI system Megasquirt (DIYautotune.com) is very popular
AE86 ex-daily |
02-09-2010, 10:46 PM
Kool thank you bean bandit! im new to this corolla thing, i go the car for 700 bucks.. so is a good proyect. what other car has the 4a-ge besides the corolla?
02-09-2010, 10:54 PM
well there are plenty of swap options you would have... but be advised there aree other differences between the SR and GT... rearaxle etc... search for SR5 to GT swaps you should find plenty of information and being new to corollas -> read,read and read some more there are ton of infos out there
AE86 ex-daily |
02-12-2010, 02:36 AM
Your best bet is to wait till you find a GT that's been written off from a good side hit, buy it cheap and swap everything over:
Engine Wiring fuel tank and lines clutch lines rear axle and brakes Front struts, brakes and all + any interior goodies that the GT may have had optioned. This will be the easiest way for you to do it. Converting a FWD engine to RWD is a little bit of mucking about. |
do efi 4age backfire? | kpretro84 | 24 | 23,241 |
03-22-2013 09:10 PM Last Post: banpei |
SAAB 90 minilites -> AE86 compatible? | Uzelac | 4 | 7,834 |
01-12-2011 07:02 PM Last Post: leckter |
what rack and pinions are compatible ae86 | Comrade_charlie | 7 | 7,803 |
08-12-2008 06:08 AM Last Post: F0Bman |
What does the EFI Main Fuse do? | jeenyus | 4 | 7,603 |
06-03-2008 10:47 AM Last Post: banpei |
Which Daihatsu parts are compatible? | Apolan | 29 | 23,597 |
11-26-2005 01:44 PM Last Post: Apolan |
