What is good oil pressure?
05-28-2011, 01:06 PM
Im only after rebuilding my 4age, it got
all new ACL bearings bottom end TRD HeadGasket Toda cams Vernier adjustable pulleys Lightweight flywheel As far as I remember on my standard gauge the cam never moved much from 3/4 oil pressure at all times. Now after the rebuild it is sitting at just over half way at idle and always above 3/4 when being drive sometimes even close to the H mark. Is the low pressure at idle normal, im just worried as im not used to it! Thanks |
05-28-2011, 01:59 PM
sounds perfect to me mate!
05-28-2011, 07:18 PM
About half idleling is perfect. More than 3/4 sounds like you have a pressure valve that doesn't open... Are you running stock oil cooler setup?
Sarcasme is just one of the things I offer ![]() Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch ![]() |
05-29-2011, 12:47 PM
i always have pressure at 3/4....why??
05-29-2011, 01:02 PM
gauges and sensors can be faulty too, and not accurate!
05-29-2011, 03:30 PM
Petros AE86 Wrote:i always have pressure at 3/4....why?? Mine used to be like that ive used a diffrent fuel sender after the rebuild so I think the old one was possibly faulty |
ClutchMaxPRO Clutches - Good or Bad? | RolanTHUNDER | 0 | 1,275 |
12-01-2022 09:55 AM Last Post: RolanTHUNDER |
Build your own adjustable fuel pressure regulator ;) | oldeskewltoy | 8 | 21,727 |
D2 Coilovers any good? | heshan | 18 | 27,209 |
Toda timing info - with good general 4AG timing info too | oldeskewltoy | 0 | 4,416 |
Oil Pressure Query | Alex170984 | 2 | 5,365 |
12-11-2014 01:25 AM Last Post: Alex170984 |
