What light flywheel?
11-28-2010, 09:33 PM
Hi, i looked for the forum, but i haven't any conclusion.
In a few weeks i'm gonna change the clutch, and i was thinking to instal a light flywheel, some questions: * Will feel the difference in a OEM engine (only will have a new cams)?? * What flywheel (no too much expensive like a beautiful TodaRacing)? and compatible with the OEM clutch * Another option is to make a OEM flywheel to light flywheel (eating the "fat"), Anybody knows where would i remove the weight? (a turner work) Thanks |
12-03-2010, 09:54 PM
1. If you go to an aftermarket flywheel you will notice a LOT of difference. Some difference with a blacktop flywheel, but not nearly as much. Because it isn't as light as the aftermarkets, but it is lighter than the stock.
2. I'd recommend a chromoly/steel type flywheel like the toda/jun/etc. 3. NO. Do not do this if you like your feet. Andrew |
12-03-2010, 10:13 PM
T_AE86 Wrote:* Another option is to make a OEM flywheel to light flywheel (eating the "fat"), Anybody knows where would i remove the weight? (a turner work) assassin10000 Wrote:3. NO. Do not do this if you like your feet. Its one thing with a V8 engine or V6 that only spin to 6000 rpm, but with the potential to spin well over 7000, a reduced "fat" flywheel is not safe. To add to that, an aluminum one is better, but as Andrew points out, try to stick with a steel unit, far safer then lightening an aftermarket flywheel Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
12-03-2010, 10:59 PM
Way too much uninformed comment, speculation and internet myth
about this topic. I suggest you try telling these guys they are doing it all wrong... http://www.racetep.com/flywheel.html Cheers... jondee86 |
12-06-2010, 11:18 AM
+1 with jondee
lots of people in the hillclimbing races drive lightened OEM flywheels above 9000rpm http://monkeymagic86.wordpress.com |
12-06-2010, 11:38 AM
Do you know someone who did it on 4AGE ?
Sounds interesting. Have local shop which is doing this and similar stuff, but they don't have expirience with 4AGE neither. |
light weight Flywheel | filh | 9 | 7,190 |
02-05-2018 05:20 PM Last Post: filh |
crank 6 bolt flywheel | DJexor | 5 | 7,938 |
12-05-2016 08:21 AM Last Post: d3nso |
Flywheel fitting | totta Crolla | 11 | 12,567 |
11-24-2013 05:31 PM Last Post: Apsogos |
Flywheel and clutch kit | 86Pilot | 1 | 3,435 |
12-01-2011 01:26 PM Last Post: 86Pilot |
flywheel balance | totta Crolla | 4 | 5,193 |
06-28-2010 11:21 AM Last Post: Bean |
