What size of tires with 14' Konig Rewind ?
10-24-2006, 10:08 PM
Hi !
I have 190/60/14 tires on my Rewind , and when I turn , the front tires rubs on the body ![]() What size is the best ? Thank you very much ! |
10-24-2006, 10:11 PM
185/60 on mine
10-24-2006, 10:19 PM
The US guys recommend 185/60 to avoid rubbing. That being said, it is not the best choice in terms of grip, although it should still handle pretty well on 185 with good suspension.
10-25-2006, 09:07 AM
Make 6mm steel spacers using worn-out rear brake discs (they are 8mm thick). With up to 6mm you still can use original wheel studs.
10-25-2006, 05:27 PM
oldskull Wrote:185/60 on mineRubs on mine, but mine was lowered a bit more than yours. ![]() Still got to remove the plastic thing in the fender though. ![]() 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
Winter tires | Ryo | 7 | 5,693 |
01-30-2020 05:33 AM Last Post: oldeskewltoy |
Shim size for AM cams | kazi | 4 | 5,429 |
Hub size | kazi | 5 | 10,050 |
Camshaft sprocket bolt size? | harkes | 1 | 4,799 |
(Video) Tips to choose a good set of tires | Homem Bomba | 1 | 4,330 |
07-22-2013 04:59 PM Last Post: Homem Bomba |
