What spring on KE70 ?
04-15-2009, 06:23 PM
Post: #31
i cannot think of any reason why that wouldnot fit.
i just changed form ke79 axle to ae86 axle, and that was a straight bolt on with all parts that are already on the car.
springs, dampers, etc.
zo i guess coilovers should fit too.
04-15-2009, 07:58 PM
Post: #32
at the rear ?
I checked all the rear axles i have and i cannot find why i can not as well Banging head
Thanks Eric
06-15-2009, 05:06 PM
Post: #33
ok so i finally did the following
- 1982 ke70 struts
- 1979 tophats
- Meganracing AE86 springs -6cm
nothing else to change and it is perfect Thumbs up!
Thanks for the help
  SOME 4AG valve spring specs oldeskewltoy 5 13,294 05-04-2015 01:17 PM
Last Post: Project D
  clutch pedal return spring Eifelaner 2 7,145 09-06-2013 10:21 AM
Last Post: Apsogos
  P-valve CLOSED --> Stiffer spring will do it :) Dino86 1 3,188 04-05-2012 04:17 PM
Last Post: Dino86
  lowering spring information HELP martyg 1 3,385 09-27-2011 01:56 PM
Last Post: martyg
  clutches and spring washers position in 2 Way TRD diff???? T_AE86 3 5,099 09-01-2011 10:50 AM
Last Post: T_AE86
