What spring on KE70 ?
02-28-2009, 07:34 PM
oldeskewltoy thanks a lot.
So i could use my shocks from TE71 on the KE70 and put this on ? I know nonone who can do that ![]() Is it like Egay ? so i can register and buy |
02-28-2009, 07:39 PM
My front setup is like this:
ae86 front strut, or TE71 agx shortstroke dampers, t3 lowering set wich basicly is grond control + eibach springs t3 camberplate weld the whole thing together and you are done for the front. you can use the te71 struts on the ke, with little modifications as i told you before in this topic. |
02-28-2009, 08:11 PM
Eric Wrote:My front setup is like this: Sorry, what is T3 ![]() |
02-28-2009, 08:23 PM
Techno Toy Tuning i think (would be more 3T than T3 but ok
03-01-2009, 10:56 AM
What if i buy a complete set of AE86 coilovers ?
I think the rear won't like it if i read well as the strut housing is not meant to have all this spring power at one place. ![]() So what about the rear ? sorry to ask but i have to see the value of everything. AGX shocks and Springs for AE86 ? i found some TRD springs for the back but 8 kg load. it is a bit too much ![]() |
03-01-2009, 11:22 AM
i never tried ae86 coils on my ke70 so cant help you with that. you can always reinforce the rear strut housing if you think that is too weak.
agx shocks and springs for ae86 will do just fine. |
03-01-2009, 01:26 PM
Eric Thank you
![]() So i have to find all this now ![]() |
03-01-2009, 01:46 PM
thats not very difficult, ask one of the traders on this board or send T3 an email, they can supply you with anything you need.
03-01-2009, 01:57 PM
i found some things on Ebay already, second hand ;-)
i am going to take [u:6049637988]For the Front :[/u:6049637988] - Cusco camber plate - T3 coilover (ground control, Eibach) - AE86 TRD shock I will weld on KE70 front strut [u:6049637988]For the rear[/u:6049637988] - AE86 rear TRD shocks - Rear TRD springs Did i make a mistake ? |
03-01-2009, 02:33 PM
Nope, sounds just fine!
SOME 4AG valve spring specs | oldeskewltoy | 5 | 13,627 |
05-04-2015 01:17 PM Last Post: Project D |
clutch pedal return spring | Eifelaner | 2 | 7,355 |
09-06-2013 10:21 AM Last Post: Apsogos |
P-valve CLOSED --> Stiffer spring will do it :) | Dino86 | 1 | 3,320 |
04-05-2012 04:17 PM Last Post: Dino86 |
lowering spring information HELP | martyg | 1 | 3,496 |
09-27-2011 01:56 PM Last Post: martyg |
clutches and spring washers position in 2 Way TRD diff???? | T_AE86 | 3 | 5,274 |
09-01-2011 10:50 AM Last Post: T_AE86 |
