What to spend my money on.
03-16-2015, 04:47 PM
(This post was last modified: 03-16-2015 06:29 PM by The Big Yin.)
Hey folks.
I will potentially have £4200 to spend on my Hachi. £2200 of that is going towards a Haltech ECU, digi dash and a full rewire. That leaves £2k to have the car painted/plasti dipped/wrapped. Refresh the suspension/brakes. Car has been off the road for 6 years. What would you do. Sent from the Crack of my Bum. Sent from the Crack of my Bum. ![]() DRIFTING is pushin a car against its intended design, then playing with the LAWS OF PHYSICS |
03-16-2015, 06:20 PM
Suspension definately. Go before show.
What kind of engine are you running with the haltech btw? AE86 Levin |
03-16-2015, 06:28 PM
It is going to be a slighy tuned 16v for now.
But I am going to turbo it in a year. So fitting it now when the full rewire is being done. No point having wiring done now, and having it redone when I turbo it. Body has to be done. No choice. Just had a lot of welding done. ![]() Car currently has TRD coilovers on front. And TRD blues on year. But with sitting so long I don't think they will be usable. Sent from the Crack of my Bum. ![]() DRIFTING is pushin a car against its intended design, then playing with the LAWS OF PHYSICS |
03-16-2015, 08:47 PM
Yeah paint work was always going to be done.
Doesn't have to be an amazing job. Because it's going to be road/track/drift. Current spec of car. Engine 7 Rib Big Port Engine ISKY Racing Cams Adj Fuel regulator Uprated fuel pump 4-1 manifold Straight through underaxle exhaust A'PEXi power intake SARD Magnetic Oil plug Grex Oil Cooler greddy radiator pipe TRD Engine mounts AirCon removed Viscous fan removed and twin electric fitted TRD Rad Cap Lightened and Balanced Crank Lightened and Balanced Conrods Full Fresh Rebuild AE101 Oil Pump for beter flow TRD 0.8mm Metal Headgasket P.A.S.S Racing Underdrive Light Weight Racing Pulleys ACL RACE SERIES Crankshaft Main Bearings ACL RACE SERIES Connecting Rod Bearings Transmission TRD Quick shift Helix Cerametalic Paddle Clutch TRD 2 way Limited Slip Differential Cusco Gearbox mount Lightened and Balanced Flywheel ARP flywheel bolts Suspenion Front CoilOvers Cusco Topmount Camber Adjustment Rear TRD adjustable shocks and Springs 'Achieve Sports' Full Roll Cage Alloy RCA's T3 Adjustable Rear Lateral Rod Front Strut Brace Full Poly Bush Kit Brakes Drilled and grooved discs all round. Cusco Brake Enhance Exterior Extreme Dimensions Body Kit TRD Spoiler Interior Corbaue buckets. MOMO 4 point harnesses MOMO Wheel and extended hub Fully stripped Oil Pressure Guage Oil Temperature Gauge Volt Gauge Water Temp Gauge All AutoGauge Smoke series Steering Battle Version Steering spacer Kit2 Sent from the Crack of my Bum. ![]() DRIFTING is pushin a car against its intended design, then playing with the LAWS OF PHYSICS |
03-16-2015, 09:45 PM
Easy suspension brakes first engine later
03-16-2015, 10:35 PM
Considering you got almost everything covered already check first if the current suspension is still in order and get the car running as is. Once you done a few track days it'll be easier to tell what potential weaknesses need to be remedied.
AE86 ex-daily |
03-16-2015, 10:55 PM
I'm thinking after 6 years suspension and brakes will likely need replaced.
Car is at a good spec. Just with having not ran for so long. Full service on engine. All new fluids. New discs and pads. Take all suspension off and see if it can be saved. Sent from the Crack of my Bum. ![]() DRIFTING is pushin a car against its intended design, then playing with the LAWS OF PHYSICS |
03-17-2015, 04:17 PM
Why do you think 6 years is too long ?
Give it a try before yuu go for new springs. Shocks should be 100%, they don't mind sitting as springs do. |
03-18-2015, 01:33 AM
(03-16-2015 08:47 PM)The Big Yin Wrote: Yeah paint work was always going to be done. More details??? Which Isky cams - (custom?) What lift, what duration? What is engines static compression? Any head work? Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
03-18-2015, 01:34 AM
I genuinely don't know bud. They were in the car when it came over from Japan!
Stabilizer Bars - Do they worth the money? | Rasteirinho | 30 | 26,845 |
03-09-2007 02:31 AM Last Post: domi |
