What to spend my money on.
03-16-2015, 04:47 PM (This post was last modified: 03-16-2015 06:29 PM by The Big Yin.)
Hey folks.
I will potentially have £4200 to spend on my Hachi.
£2200 of that is going towards a Haltech ECU, digi dash and a full rewire.
That leaves £2k to have the car painted/plasti dipped/wrapped.
Refresh the suspension/brakes.
Car has been off the road for 6 years.
What would you do.
Sent from the Crack of my Bum.
[Image: AEU86 AE86 - What to spend my money on.]
DRIFTING is pushin a car against its intended design, then playing with the LAWS OF PHYSICS
03-16-2015, 06:20 PM
Suspension definately. Go before show.
What kind of engine are you running with the haltech btw?
AE86 Levin
03-16-2015, 06:28 PM
It is going to be a slighy tuned 16v for now.
But I am going to turbo it in a year.
So fitting it now when the full rewire is being done. No point having wiring done now, and having it redone when I turbo it.
Body has to be done. No choice.
Just had a lot of welding done.
Car currently has TRD coilovers on front.
And TRD blues on year.
But with sitting so long I don't think they will be usable.
03-16-2015, 08:47 PM
Yeah paint work was always going to be done.
Doesn't have to be an amazing job. Because it's going to be road/track/drift.
Current spec of car.
Engine
7 Rib Big Port Engine
ISKY Racing Cams
Adj Fuel regulator
Uprated fuel pump
4-1 manifold
Straight through underaxle exhaust
A'PEXi power intake
SARD Magnetic Oil plug
Grex Oil Cooler
greddy radiator pipe
TRD Engine mounts
AirCon removed
Viscous fan removed and twin electric fitted
TRD Rad Cap
Lightened and Balanced Crank
Lightened and Balanced Conrods
Full Fresh Rebuild
AE101 Oil Pump for beter flow
TRD 0.8mm Metal Headgasket
P.A.S.S Racing Underdrive Light Weight Racing Pulleys
ACL RACE SERIES Crankshaft Main Bearings
ACL RACE SERIES Connecting Rod Bearings
Transmission
TRD Quick shift
Helix Cerametalic Paddle Clutch
TRD 2 way Limited Slip Differential
Cusco Gearbox mount
Lightened and Balanced Flywheel
ARP flywheel bolts
Suspenion
Front CoilOvers
Cusco Topmount Camber Adjustment
Rear TRD adjustable shocks and Springs
'Achieve Sports' Full Roll Cage
Alloy RCA's
T3 Adjustable Rear Lateral Rod
Front Strut Brace
Full Poly Bush Kit
Brakes
Drilled and grooved discs all round.
Cusco Brake Enhance
Exterior
Extreme Dimensions Body Kit
TRD Spoiler
Interior
Corbaue buckets.
MOMO 4 point harnesses
MOMO Wheel and extended hub
Fully stripped
Oil Pressure Guage
Oil Temperature Gauge
Volt Gauge
Water Temp Gauge
All AutoGauge Smoke series
Steering
Battle Version Steering spacer Kit2
03-16-2015, 09:45 PM
Easy suspension brakes first engine later Smile
03-16-2015, 10:35 PM
Considering you got almost everything covered already check first if the current suspension is still in order and get the car running as is. Once you done a few track days it'll be easier to tell what potential weaknesses need to be remedied.
AE86 ex-daily
03-16-2015, 10:55 PM
I'm thinking after 6 years suspension and brakes will likely need replaced.
Car is at a good spec. Just with having not ran for so long.
Full service on engine. All new fluids.
New discs and pads.
Take all suspension off and see if it can be saved.
03-17-2015, 04:17 PM
Why do you think 6 years is too long ?
Give it a try before yuu go for new springs.
Shocks should be 100%, they don't mind sitting as springs do.
03-18-2015, 01:33 AM
(03-16-2015 08:47 PM)The Big Yin Wrote:  Yeah paint work was always going to be done.
Engine
ISKY Racing Cams
Full Fresh Rebuild
More details??? Which Isky cams - (custom?) What lift, what duration? What is engines static compression? Any head work?
Dan -
03-18-2015, 01:34 AM
I genuinely don't know bud. They were in the car when it came over from Japan!
  Stabilizer Bars - Do they worth the money? Rasteirinho 30 25,930 03-09-2007 02:31 AM
Last Post: domi
