Where is located lambda on ae86
08-18-2006, 12:01 AM
Indeed, follow the advise of Knudsen.
Go to the garage, measure co2 and adjust the mixture. Succes |
08-18-2006, 12:08 AM
Well.. Youre not guarenteed succes, the mixturepart can be faulty...
08-18-2006, 12:13 AM
The injectors can be the problem too...
Sarcasme is just one of the things I offer Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch |
08-18-2006, 09:48 AM
The injectors have been also changed so there is no problem... i didnt try to exchange this part that you Knudsen showed i will try that to replace.
85' AE86 GT coupe lifetime project since 2005 |
08-18-2006, 11:18 AM
not replaceing it...adjusting it is what he advizes. This little adjuster can change the idle mixture. If you look how it's connected to the rest of the wiring you'll see that it is directly connected to the TPS sensor wires, so you might want to check if that sensor is adjusted properly (grab your manual and a multimeter).
08-18-2006, 03:29 PM
What if there is problem with tvis butterfiles if they are stuck or not working correctly and air to engine is restricted ? Can be there some problem ?
08-18-2006, 05:58 PM
Not likely...TVIS is normally open, and is pulled closed by the electric actuator using vacuum once you start the car.
08-18-2006, 06:24 PM
I forgot to mention one thing the car has unpluged hose to vacuum sensor because when i plug it in the car is instantly idling about 3500rpm also when is cold and also when the engine is warm.
When i unplug it the rpm is about 900-1000. 85' AE86 GT coupe lifetime project since 2005 |
08-18-2006, 06:31 PM
Ehm...you just unplug the most important sensor your ECU has to work with and complain about mileage? Plug it back in... the idle problem is something completely different. Usually it's either a bad auxiliary air valve/clogged heater lines to the aux air valve or maybe the throttle plate is maladjusted and always stuck open.
08-18-2006, 06:45 PM
Can you show me on pics so i can just understand it better i realy suck with identify this things or just if you can give me the page on ae86 manual where i can find it i downloaded the manual from this site some time ago.
Lambda sensor wiring | sam3007 | 10 | 4,275 |
looking for Lambda Oxygen Sensor for my ae111 blacktop | Hachi-man | 1 | 3,147 |
04-19-2012 01:19 AM Last Post: Hachi-man |
Manifold/lambda problems | gjuro | 3 | 4,841 |
11-20-2009 01:06 AM Last Post: jondee86 |
Lambda sensor | totta Crolla | 6 | 6,152 |
10-28-2009 09:54 PM Last Post: totta Crolla |
How it's located the engine serial number? | Mattolo | 5 | 5,444 |
04-04-2009 06:36 PM Last Post: oldeskewltoy |
