Where to run the factory antenna cable
09-12-2020, 02:16 PM
hi team i have jdm ae86, i am confused about what hole to use when running the antenna cable to the stereo.
[Image: AEU86 AE86 - Where to run the factory antenna cable]
09-13-2020, 02:35 PM
It should come through the same grommet that the big wiring loom passes through.
09-30-2020, 12:31 PM
(09-13-2020 02:35 PM)Ivan141 Wrote:  It should come through the same grommet that the big wiring loom passes through.
Yes, Sorted! thank you.
  Trunk and fuel door cable pack 2 6,537 04-23-2018 11:01 PM
Last Post: pack
  ae85 kickdown cable MIGGZFSU 0 3,094 05-04-2017 04:23 PM
Last Post: MIGGZFSU
  Machining Pistons to run 20v head... And FCR's on a 20v? PazzaAE86 2 5,084 09-15-2013 01:08 AM
Last Post: jondee86
  Length of factory cat Rick 4 7,653 08-07-2013 06:03 AM
Last Post: jondee86
  Ke70 acc cable? TheGerman 3 4,954 04-15-2013 12:37 PM
Last Post: TheGerman
