Which threadsize to use for the vdo oil temp sensor?
03-07-2012, 11:19 PM
Hello,
This friday i am going to buy some vdo meters for the ae86 and the sensors
=>oil temp gauge
=>water temp gauge
=>volt gauge
I found an interesting topic here on the forum thats says you can use
But there is a drain valve for the water, just 2cm toward the cabin,and there is a plug in the oilpump 2cm infront of the pressuresensor,that can be used for oil temp,it´s directly in the oilflow into the engine from the pickup.
[Image: AEU86 AE86 - Which threadsize to use for...p  sensor?]
Now there are alot of different sensors with thread that can be bought and i dont know which ones i need to get :s
sensors with different thread
Anyone who knows which one i need to buy?
03-08-2012, 03:26 AM
water drain plug => 1/4 BSPT
oil pressure sensor = 1/8 BSPT
For the oil pump I can't tell right now but I'm pretty sure it's a 3/8 BSPT.
Be careful:
NPT = National pipe thread -> U.S. standard
BSPT = British Standard Pipe Taper thread (Also used as a standard in Japan)
03-08-2012, 08:10 PM
thanks
I have found the vdo meters but couldnt find the 3/8 bspt sensor
Do you have any idea which one from this website i need to use?
http://www.rpower.be/index.php?option=co...itstart=16
03-08-2012, 09:12 PM
I think you might buy brass adapters.
For the oil temp:
3/8 to M10x1 Adapter -> Ask if it's BSPT (Taper) or BSPP (Parallel), if it's BSPT you're good to go !
Oil temp sensor
It's more for the water temp that you will have a problem, because VDO don't make sensor in BSPT and I don't see any 1/4 BSPT adapter on your dealer's website...
BUT you can buy something like THIS
And so you can buy this Water temp sensor
(And I don't speak dutch, so dutch website doesn't really help me to help you...)
03-08-2012, 10:59 PM
many thanks for the help Smile
the oil temp is the most important one for now because the digital dash has no oil temp.
water temp is for bit later.
03-09-2012, 06:37 PM
Its BSPP
Guess i will have to ask arround more
03-14-2012, 09:32 PM
The correct place to messure oiltemp, are in the oilpan :wink:
Project AE86 now begun.
Cars I have owned:
Toyota Starlet EP91 1,3 16v Turbo, 200hp
Toyota Starlet EP71 1,3 12v Sport
Mercedes 207D camper, 1977.
Toyota Starlet EP70 with a 174hp Silvertop 20v See video here:
http://videos.streetfire.net/search/Star...079edc.htm
Toyota Corolla AE101 with a 164hp Silvertop 20v. (Evolution bodykit and candycolor paint).
Volvo 240 2,1 (The only car I have maked money on).
Toyota Corolla EE90 (my first car)
03-15-2012, 01:56 AM
Jimmi The Kid Wrote:The correct place to messure oiltemp, are in the oilpan :wink:
Before (in the oil pan) or after the oil pump, it doesn't change anything.
But for rallying I will never attach a sensor under the car, it's the best way to snatch everything.
  20v BT - which oil pump? Mylesmck 4 2,913 06-21-2022 04:51 PM
Last Post: pack
  Lambda sensor wiring sam3007 10 4,688 05-23-2022 10:00 PM
Last Post: The Doctor
  Rim width. Which is best.... Dino86 5 6,909 01-07-2017 03:09 PM
Last Post: Dino86
  which connector is this ditn 7 7,860 07-27-2015 11:24 AM
Last Post: pack
  Haslbeck front spoiler, which foglights? wouter86 2 5,165 02-15-2015 11:14 AM
Last Post: ditn
