White Kouki Trueno Hatch, 20V BT, FC3S brake, Watanabe MG,
01-03-2011, 03:41 PM
Post: #31
some updates
honda stream brake booster
[Image: AEU86 AE86 - White Kouki Trueno Hatch, 2...tanabe MG,]
01-03-2011, 04:14 PM
Post: #32
some stuffs
redline tail light
since the tail light rubber seal is in bad condition, I used rubber that was cut in shape instead
Itavolanti Admiral steering
(almost 30 yrs old but in mint condition )
01-07-2011, 02:43 PM
Post: #33
Question: why did you use a Honda Stream brake booster?
Thanks
01-07-2011, 03:12 PM
Post: #34
Ozone Wrote:Question: why did you use a Honda Stream brake booster?
Thanks
Hi
Because
1.its size is bigger than the OEM one ( 1.5 step)
2. it is the biggest size that can be fitted to hachi without hitting body Thumbs up!
3. It can be fitted without any modification
01-14-2011, 06:47 AM
Post: #35
redlines Smile
interior
trd rear wing, just test fit Cool
01-17-2011, 05:23 PM
Post: #36
Since ther was some member message to me about the water line of the engine,
I took the inlet and outlet of my engine here below Smile
If any mistake I would like to say sorry Respect!
The maintained water outlet line
The closed inlet line on the exhaust side.
new inlet line at intake side
01-17-2011, 05:37 PM
Post: #37
Aluminum header adapter to adapt 4age bluetop header to 20v BT block
01-17-2011, 05:39 PM
Post: #38
TRD clutch and flywheel( which I think it is C-one motor sport 4.4kg )
01-24-2011, 04:09 PM
Post: #39
Thanks for the pictures. But have you also pictures of how you made the delco rebuild?
Nice work!
Grtz...
Corolla GT AE86 rally ('87) ....
Corolla GT AE86 rally/historic ('83) nog werk aan...
Corolla GT AE86 in opbouw ('84) ...
01-29-2011, 07:43 PM
Post: #40
another pics for engine
after modification the header adapter with waterline hole.
another 4AG engine, this one is from this car, put it out, clean and change some essential parts such as timing belt, gasget, seal ETC.
Watanabe MG with 195/50/15 BF-Goodrich G-force tire
  Trueno Hatch and Levin Coupe - Repair, replace, pray xD TomRich 13 15,076 10-07-2018 09:45 PM
  Adam's white, rusty levin...updated 23-09-2018!! adomz 150 149,557 09-23-2018 05:14 PM
Last Post: adomz
  86er Levin Hatch from Germany ArToAE86 19 16,560 01-24-2018 10:35 PM
Last Post: ArToAE86
  Lauren's 1985 Kouki Trueno Lauren 161 189,921 09-01-2015 08:46 PM
Last Post: Lauren
  OST-026: "My White Hatch" oldeskewltoy 49 58,901 07-03-2014 11:56 PM
