Why is my engine cross member cut back?
11-06-2005, 04:41 PM
After having a good look under the car today i noticed the engine cross memeber has been cut back with a gas torch. It looks like the sump would note clear it otherwise. Any one have the answer?
Topic title modified by banpei (admin) |
11-06-2005, 08:52 PM
Bigger than standard sump pan ?
Check the brackets that are attached to the engine from the cross member - maybe they have been shortened and the engine is lower in the car ? Regards Ian. |
11-06-2005, 09:24 PM
yeh! you can see the engine mounts have been shortened and repositioned.
11-06-2005, 10:41 PM
Ah - good stuff.
A bit lower centre of gravity. Regards Ian. |
20 Valve Blacktop smoking after engine flush - why? | RolanTHUNDER | 2 | 1,398 |
Can you convert your 86 back too the original state? | gh0st | 7 | 2,965 |
Exhaust has white smoke coming out and I dont know why... | mister86 | 3 | 4,631 |
01-19-2020 12:06 AM Last Post: Power_uP |
Why Zenki and Kouki colour difference | MIGGZFSU | 10 | 19,112 |
04-23-2017 09:16 AM Last Post: MIGGZFSU |
DIY: a quick outline on why & how to set pinion angle. | assassin10000 | 9 | 18,485 |
