Why is my engine cross member cut back?
11-06-2005, 04:41 PM
After having a good look under the car today i noticed the engine cross memeber has been cut back with a gas torch. It looks like the sump would note clear it otherwise. Any one have the answer?
[Image: AEU86 AE86 - Why is my engine cross member cut back?]
Topic title modified by banpei (admin)
11-06-2005, 08:52 PM
Bigger than standard sump pan ?
Check the brackets that are attached to the engine from the cross member - maybe they have been shortened and the engine is lower in the car ?
Regards Ian.
11-06-2005, 09:24 PM
yeh! you can see the engine mounts have been shortened and repositioned. Thumbs up!
11-06-2005, 10:41 PM
Ah - good stuff.
A bit lower centre of gravity.
Regards Ian.
  20 Valve Blacktop smoking after engine flush - why? RolanTHUNDER 2 1,398 11-30-2022 12:09 PM
Last Post: RolanTHUNDER
  Can you convert your 86 back too the original state? gh0st 7 2,967 04-25-2022 04:25 PM
Last Post: gh0st
  Exhaust has white smoke coming out and I dont know why... mister86 3 4,631 01-19-2020 12:06 AM
Last Post: Power_uP
  Why Zenki and Kouki colour difference MIGGZFSU 10 19,112 04-23-2017 09:16 AM
Last Post: MIGGZFSU
  DIY: a quick outline on why & how to set pinion angle. assassin10000 9 18,485 12-21-2016 10:28 PM
Last Post: ditn
