Wierd Dyno result
05-05-2005, 09:52 AM
Wierd Dyno result
But you need to remove the oil pan. That means - engine out of the engine bay.
05-05-2005, 10:55 AM
Wierd Dyno result
Why take out the engine, when you can remove the oilpan with the engine in the bay?
05-05-2005, 10:57 AM
Wierd Dyno result
Knudsen Wrote:Why take out the engine, when you can remove the oilpan with the engine in the bay?Can you ? I cannot. |
05-05-2005, 11:00 AM
Wierd Dyno result
you cant Knudsen coz the engine stands on the front crossmember and not on tne chassis, which (crossmember) has to be removed if you want to remove the oil pan..
05-05-2005, 06:16 PM
Wierd Dyno result
Apolan Wrote:you cant Knudsen coz the engine stands on the front crossmember and not on tne chassis, which (crossmember) has to be removed if you want to remove the oil pan.. Really..... i cant.....? MuHaHaHa.. The only thing you have to dismount, is the gearbox brackets on each side The enginemounts isnt attached to the oilpan :wink: Youtube Myspace and I´ll Google your Yahoo |
Ignition advance, Dyno and Detonation | apardal | 10 | 14,741 |
04-21-2008 11:02 AM Last Post: KrizKH |
Dyno proven header for AE86 ????? | jondee86 | 10 | 13,690 |
03-27-2008 05:15 PM Last Post: oldeskewltoy |
Rear oil strainer - 6 bolts - wierd feeling?! | Apolan | 7 | 6,007 |
02-26-2008 03:13 AM Last Post: Apolan |
AE86 Dyno Results! | Wraith | 9 | 13,846 |
10-16-2006 09:13 AM Last Post: Mux213 |
Wierd and annoying rattling noise | Knudsen | 14 | 12,934 |
04-13-2005 01:24 PM Last Post: Knudsen |
