Wiring JDM / Euro tails
11-23-2013, 11:47 PM
I did it a few years ago, i can't remember, but i think i only change a pin...or two, on monday i'll take a look
[Image: AEU86 AE86 - Wiring JDM / Euro tails]
11-25-2013, 01:17 AM
Not 100% sure what I did, but its like switch 2 and change the 3rd one dont even need a multimeter to do this Wink
Leave one of the old taillights in and fit a new one, while using the old light as reference what should be switched on, ie. indicator, brake, you will see what does and what doesent work on your new one.
Trace the wire colours of the functions, that dont work on the JDM light on, the EU light and check were they are pinned on the plug. Change it acording to the EU pinout on the JDM light.
Colour are the same on both lights so its easy Wink
Edit: Yes the foglight function is not avaliable the the JDM light!
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
11-25-2013, 02:10 PM
Checked!
If i'm not mistake, i remember indicator and rear gear light are the same, I connected it and it worked, the problem were the red lights. I checked the right taillight, this is the pin position to work in Eurpean wires:
I hope it helps
11-25-2013, 09:48 PM
Compare the wire colors and pin locations on the usdm and jdm light plugs. IIRC only 1 wire/pin needs to be moved on each jdm/euro tail light to match the usdm configuration.
11-26-2013, 12:20 AM
Cool!!
Thanks guys, I will certainly get it to work now!
The lights are being refurbished a bit now, so when I get them back I will take some pics of what I did. Thumbs up!
  Tail light wiring... Mylesmck 4 1,125 02-02-2024 12:36 PM
Last Post: Mylesmck
  Lambda sensor wiring sam3007 10 4,652 05-23-2022 10:00 PM
Last Post: The Doctor
  4A-GE wiring engine to chassis connectors Lykowsky 4 7,100 06-20-2019 11:38 AM
Last Post: Lykowsky
  Some wiring help needed DJexor 5 5,597 05-18-2019 01:50 PM
Last Post: DJexor
  AE86 Headlight + wiper wiring (levin) bozu 11 16,233 09-19-2017 02:06 PM
