Wiring help
09-25-2007, 07:08 AM
Wiring help
so the wiring Diagram I have for the silvertop is kinda all in japanese so I dont understand anything other than the little bit someone translated for me which is just the name for the sensors. but I really need to know the wire colors for things such as the TPS that have 4 different wires going to it. Any help would be appreciated, Im trying to wire the silvertop to the Megasquirt relay board that I finished
09-25-2007, 08:40 AM
Wiring help
The throttle position sensor has two "signals" going in and two going out. The ECU/harness feeds it +5V (VC) for reference and ground - it returns back a variable voltage signal (VTA) for the throttle position and an idle switch signal (IDL) which connects to ground when the throttle is closed. You can see all these signal names and TPS pin numbers on the 20v silvertop diagram.
Edit: Oh yeah, this might be useful for working out the colors;
http://japanese.about.com/bl_colors.htm
09-25-2007, 04:43 PM
Wiring help
thanks a lot this will help
  Tail light wiring... Mylesmck 4 1,310 02-02-2024 12:36 PM
Last Post: Mylesmck
  Lambda sensor wiring sam3007 10 4,917 05-23-2022 10:00 PM
Last Post: The Doctor
  4A-GE wiring engine to chassis connectors Lykowsky 4 7,319 06-20-2019 11:38 AM
Last Post: Lykowsky
  Some wiring help needed DJexor 5 5,745 05-18-2019 01:50 PM
Last Post: DJexor
  AE86 Headlight + wiper wiring (levin) bozu 11 16,752 09-19-2017 02:06 PM
