Wishbone/control arm
01-22-2008, 12:04 AM
I am looking for the ball joint for the lower control arm for ae86. The local dealer doesn't sell it, only the hole control arm with the ball joint
A part number and some companies that make them would be good Thanks AE86 Levin 2. door 1987-In restoration AE86 Levin 2. door 1984-In parts |
01-22-2008, 07:53 AM
i was searching for the exact same thing a few days ago
![]() so, there you are http://www.profi-autoteile.de/?mx_sessio...shopList&v[r][0]=3475&v[r][1]=100581 Part# NK Autoteile 5044504 Quinton Hazell QSJ782S |
05-15-2008, 04:50 AM
I heard you have to burn out the old one with a torch to install a new one.
05-15-2008, 06:15 AM
the Doctor (on this forum) knows how to do this..I believe you can press out the old joint and press in a new one..
05-25-2008, 12:58 PM
no, they are held in by a circlip from above, and u can actually hit them out (downwards) with a copper hammer, they arent such an interference that they require pressing in or out, usually.
05-25-2008, 09:16 PM
Usually people use a torch to burn them out and replace the ball joint. Other than that you have to buy the whole control arm assembly from the dealer.
| Front arm - Price | Lipinhu | 7 | 9,110 |
05-28-2007 03:11 PM Last Post: banpei |
