ZDoman's projects - Hungary
01-01-2007, 10:57 PM
Post: #71
ZDoman,
Be carefull mate, that's how we destroyed one of Robokills engines. That sandblasting grit gets into the tiniest holes of your engine and it wont come out until you start driving around. Sandblasting grid floating around in your oil = dead engine and loads of unusable parts.
You better spends HOURS cleaning those parts and make sure that grid is NOWHERE to be found. Make sure to find all those irritating little oil groves and such or you'll be in a world of hurt once your engine is back together.
Never sandblast engine parts, we learned the hard waySad Dont make that mistake...
01-01-2007, 11:07 PM
Post: #72
Mux213 Wrote:ZDoman,
Thank you for your advice, its too late. as you see it happened in march, by this time my engine has died Sad
I spent hours to make it clean... first I blew it with compressed air. Then I blow it with engine washer fluid, also compressed to 5-6 bar of pressure. after this with high pressure water and finally air again. The engine died after 800 race kilometers. It was enaugh for one season...
01-01-2007, 11:13 PM
Post: #73
Smallport intake modified to fit AE86
[Image: AEU86 AE86 - ZDoman's projects - Hungary]
01-01-2007, 11:15 PM
Post: #74
Engine parts cleaned
01-01-2007, 11:27 PM
Post: #75
26.03.2006
I knew that I won't have time to prepare the car for painting so I coslettized it (dye with some rust proof stuff) And I took the car into the empty sock factory Smile Smile of my friend (thank you Kapus Hurray! )
01-01-2007, 11:33 PM
Post: #76
17.03.2006
Engine assembling
The oil pump had no wear so I decided to use it against a new one.
Sleeping engine Smile
01-01-2007, 11:41 PM
Post: #77
19.03.2006
Engine assembling #2
I had time to do it only in the nights that's why I did it on several days.. Daytime I had to work.
01-01-2007, 11:45 PM
Post: #78
21.03.2006
Engine assembling #3
"catched" moment of me Smile
Engine is 'ready'
01-01-2007, 11:48 PM
Post: #79
29.03.2006
Alu parts collected for anodizing
01-02-2007, 12:51 AM
Post: #80
That's a goodlooking engine you built. Hope it runs nicely too, but then most 4age's do.
  ZaX's new projects ZaX 6 2,659 01-21-2023 07:23 PM
  My Friend's Projects Started. ToyotaTs 72 55,643 01-19-2010 08:24 PM
Last Post: oldskull
  Drift project from Hungary AE86_Z 66 91,910 12-14-2008 12:37 PM
Last Post: AE86_Z
  Foto from ROTACHI projects 2009 jardapek 3 5,734 11-17-2008 11:02 PM
Last Post: jardapek
  Projects section rules banpei 2 38,378 02-18-2005 11:24 AM
