ae86 Trueno f20c Built to be driven not polished
06-19-2012, 02:28 PM
really nice job man
any new update
AE86 with SR20 (under development)
10-03-2012, 01:04 PM
well done
JZD
10-03-2012, 02:56 PM
Ah, someone who chose to take the effort and install the F20C the way it was meant to go in. Nicely done, but the vids don't seem to show up on my end, is anyone else having the same problem ;-)
08-06-2013, 09:38 PM
Thank's guys!
Few pics from couple of track days
[Image: AEU86 AE86 - ae86 Trueno f20c Built to b...t polished]
08-06-2013, 09:42 PM
And few from BDC licensing day
08-06-2013, 09:53 PM
Last update is Toyota Previa's rear axle with is200 Cusco LSD.
That has way thicker halfshafts, so hope will be able to forget the snapped shafts for long. Also final gear should hold much better, as really got fed up of breaking them. Went trough probably 4 sets of ae86 final gears, so this one should hopefully give peace of mind.
More detailed pics will add later.
So Previa's axle is 11cm wider, so sadly original arches had to go and instead CBY arches were fitted at the rear. Should fit on the front as well to balance the look, but this will happen some time later.
08-13-2013, 02:47 AM
Can you post pics of the mods to the rear end to fit previa axles....Thanks :-)
08-13-2013, 03:33 PM
ae86drftr Wrote:Can you post pics of the mods to the rear end to fit previa axles....Thanks :-)
Shortly, some Previas have solid rear axle, so all was to do, was to remove brackets from Previa axle, then nicely remove brackets from ae86 axle and weld them onto Previa axle, which appears to be extremely similar to ae86 axle only 11cm wider.
LSD is from lexus is200 that fits perfectly bolt on Previa's diff.
Halfshaft studs were made to 4x114 to fill ae86 wheels.
Other mods were coilovers and brakes, that will show on pics that will add later as that will save thousand words Smile
08-13-2013, 03:46 PM
have you dynoed it?
08-13-2013, 06:36 PM
Petros AE86 Wrote:have you dynoed it?
No, haven't dynoed it yet as that's just a standard f20c so it should be someting like 230bhp and ~200Nm of torque
It has lightened flywheel fitted, so it revs a bit faster
  (Catching up) OST-086 MM: Built for Mario oldeskewltoy 2 2,336 10-28-2022 08:23 AM
Last Post: decryphe
  NOT SO Duty Free Trueno Hama86 25 24,141 08-16-2021 09:54 PM
  Racecar: TRD USA built ITA AE86 oldeskewltoy 38 42,968 07-22-2019 02:55 PM
Last Post: apardal
  BT20V out F20C in !! malejyetti 54 71,038 06-17-2015 07:05 PM
  wiring digram for an f20c to ae86 ae86 for sale 0 4,781 05-21-2014 11:52 PM
Last Post: ae86 for sale
