02-26-2012, 11:27 PM
Post: #41
http://www.electromotive-inc.com/products/xdi.php
direct engine managment you ajust the timing from inside of the car with your hands .
and cancel the vvti put ajustable cam gears.
all is needed .
also more easy for the non vvti engines just use fcr carbs and the electromotive .
100 percent garanty more power from all itbs .
and more easy to work .
1976 TA28 CELICA
1978 PUBLICA PICKUP
1980 4WD PICKUP
1983 AE86 LEVIN
2007 AYGO
02-27-2012, 07:01 AM
Post: #42
so you are losing power by going carbs and getting rid of the best part of this motor ,the vvti
you wont make more power with carbies thats just bullshit .thats why we have efi ,delivers the right amount of fuel at the right time and also when the cam adavances or retards
oh well you can go back to the stone age
there are 4 ecus that can do vvti link ecu from new zealand
adaptronic from aussie motec from aussie autronic and theres probaly more new 1 coming out all the time
im using cams with 14.65mm of lift and still using vvti plus i have 2stage injection
these cams are full on race versions that i use .power on this motor is from 2000 to 9400 rpm about 340 hp and a flat torque curve from 3500 and starts to drop off after 8500 rpm i dont get ,but good luck with you project
02-27-2012, 12:35 PM
Post: #43
hi dear friend .
first this carbs are not from stone age .
check all drag motorcycles they are usin these carbs also the top fuel bikes .
also the m1 yamaha was racing with carbs and was makin more power than the ecu after just the fuel consumption was to hi .
with good carbs and good ajusment you make same power or even more .
motorcycle technology is far more advanced than the cars .
did you ever try fcr carbs to fit in the 1,6 engines .
take a look at the japanese almost all of them use fcr carbs they are 41mm
and they open them at 43mm. drive first a car with proper carbs and after tell me about it .
a friend of mine put the lectron carbs in a honda civic bore to 1900cc and produce 338bhp .
with stone age carbs????
1976 TA28 CELICA
1978 PUBLICA PICKUP
1980 4WD PICKUP
1983 AE86 LEVIN
2007 AYGO
02-28-2012, 06:40 PM
Post: #44
car return from sand blust and start the welding.
1976 TA28 CELICA
1978 PUBLICA PICKUP
1980 4WD PICKUP
1983 AE86 LEVIN
2007 AYGO
02-28-2012, 07:02 PM
Post: #45
once again nice build - pitty about ditching the vvti though (could have modified a regular 3sge) and I agree with Celica RA45.
your example are good and true if you neglect the fact of the vvti which non of your examples do but the Beams does.
Anyway keep up the else very nice build.
02-28-2012, 07:19 PM
Post: #46
Bean Bandit Wrote:once again nice build - pitty about ditching the vvti though (could have modified a regular 3sge) and I agree with Celica RA45.
thanks
just in a race car you dont need vvti cose with close ratio gearbox you work you gear changes so close that you dont drop under the 6000rpm .
also i am goin to save a lot of weight .
for now i will run with the sxe10 6 speed gearbox after i am goin for quaife 6 speed sequantial .
sorry for my mistakes some times in english .
Thanks
1976 TA28 CELICA
1978 PUBLICA PICKUP
1980 4WD PICKUP
1983 AE86 LEVIN
2007 AYGO
03-16-2012, 06:03 PM
Post: #47
x4 52mm front 50mm at rear .
they just came from USA .
1976 TA28 CELICA
1978 PUBLICA PICKUP
1980 4WD PICKUP
1983 AE86 LEVIN
2007 AYGO
03-19-2012, 03:14 AM
Post: #48
Good work in the welding..
05-10-2012, 01:18 PM
Post: #49
next week comin the roll cage .
more fotos in couple weeks .
1976 TA28 CELICA
1978 PUBLICA PICKUP
1980 4WD PICKUP
1983 AE86 LEVIN
2007 AYGO
05-10-2012, 01:57 PM
Post: #50
more
1976 TA28 CELICA
1978 PUBLICA PICKUP
1980 4WD PICKUP
1983 AE86 LEVIN
2007 AYGO
  Racecar: TRD USA built ITA AE86 oldeskewltoy 38 43,399 07-22-2019 02:55 PM
Last Post: apardal
  Krullibulls Ae86 BEAMS is the only way krullibull 86 89,508 05-07-2019 09:35 PM
  Aram's 3SGE Beams Levin Coupe robokill 665 740,505 09-03-2017 09:24 PM
  AE86 GTV-Multipoint Cage, Beams, AP Brakes & Brides Conrad 462 611,947 06-27-2017 12:21 PM
Last Post: DJexor
  S.K.s AE86 racecar S.K. 207 223,994 09-18-2016 11:39 AM
Last Post: totta Crolla
